Hot Rods Coolant catch can????
Discussion in 'The Hokey Ass Message Board' started by 46international, Aug 27, 2014.
  1. blackjack, thanks man.
    tannergang, lot of truth to that! do you have a pressurized system? I don't blow out too much, unless it is over 90* outside of I do a couple of hard runs. back in the spring I did not loose any after the system found the level it liked.
  2. TANNERGANG
    TANNERGANG
    from alabama
    Yes it's a pressure cap...don't know the poundage..got a chrome cap cover on it......I'm sure it is what ever Walker recommended.
  3. Ford Mike
    Ford Mike
    Granted a flathead is a totally different animal but I thought I needed a catch can for my car. I'm running a 10lb cap on it as well. It turns out it stops spitting out antifreeze when it gets to a happy level. When it warms up it runs fine, and I don't run one anymore. Maybe I'm way wrong
  4. I will be doing the same on my T, I have a 28-29 radiator that I want to pressurize . I was thinking of using 2 1/2-3 inch br*** or copper tube with a radiator cap on top. There are some very nice examples shown here !! JW
  5. Kewl Bus
    Kewl Bus
    from NE GA
    On a related question, what size line does one use to run to the catch can?
  6. Around 5/16 I/D hose. JW
  7. Uncle Bob
    Uncle Bob
    from Salado, Tx
    Old idea......
      175.9 KB
  8. indyjps
    indyjps
    I'm on the lookout for a vintage coffee thermos for this same thing, get an aluminum or stainless, weld a hose bung onto it and attach with fire extinguisher pull clamps. If you're not pressurized just unclamp the thermos and raise it, the coolant will flow back in.
  9. Kustomism
    Kustomism
  10. Keep
    Keep
    I used a stainless steel water bottle. You can find them in all shapes and sizes.
    You can just see it on the right.
    I have been looking for a new cap for it, the plastic is kinda blah.
  11. Kustomism
    Kustomism
  12. 26hotrod
    26hotrod
    from landis n c
    I am using a moon water recovery tank like the one pictured above for several years now. I t's hooked to a Griffin alumn. radiator pressurized on a 383 stroker motor. Temps are 180-190 degrees year round. Hope this helps....................
    Hudson31 likes this.
  13. olds vroom
    olds vroom
    I used a small fire extinguisher body for mine . You can get them at any s**** yard in many sizes and the tops are already off.
    They told me it couldn't be done... So I'll try it.
  14. Kewl Bus
    Kewl Bus
    from NE GA
    Thanks JW. Olds I am using one of those Pyrene type extinguishers I found one with a mounting bracket
  15. blue 49
    blue 49
    from Iowa
    Mine was a piece of rigid aluminum conduit that I had ends tigged onto. then, I turned the whole thing in my lathe to smooth it out. It has a siphon tube on top and a drain plug on the bottom.
    Blue
      194.2 KB
    saltflats likes this.
  16. mgtstumpy
    mgtstumpy
    Just got back from a friends and he used a small old yellow 'Halon' 2 1/2lb fire extinguisher case (Banned here since 1995). Cut off the top as shaft extended to the bottom and drilled and taped a small bard fitting into side. Used the OEM mounting bracket. Damn, wish I took a photo. Looks trick
  17. scott51
    scott51
    That's slick man, clean, simple and looks like it belongs there. Any chance you'd have a better pic?
  18. I USE A WISKEY FLASK
  19. how big is the flask?
  20. kuhn1941
    kuhn1941
    My fix to a factory 1965 ford fairlane - ran the overfull hose to a 16 oz plastic water bottle with the tight hole drilled in the top . This worked great for a coolant retrieval method .
