coolant fan sender position???
Discussion in 'The Hokey Ass Message Board' started by raj4851, Sep 16, 2013.
  1. raj4851
    raj4851
    from Decatur Il
    I'm about to install an electric coolant fan in my '39 Ford with a 355 SBC. I have a capillary type sender with the knob to adjust. Should it be in the top tank or bottom? I don't want to use the pet**** location. Also, should I consider a sender? If so, where is a good mounting location? Thanks in advance, Rod
  2. willys1
    willys1
    from South Ga
    top tank or top of engine where the hottest coolant is :)
  3. Stu D Baker
    Stu D Baker
    from Illinois
    When I built my 37 Ford (24 years ago), I put the sensor in the bottom tank (removed the pet****). Running a Walker radiator and have never had a problem.
    This isn't to say willys1 is wrong, but just how I did it and it works. Stu
  4. As long as it is coolant, as you'll be setting the turn-on temperature with the dial. Mine is in the pet**** fitting, and I recently loosened the crush nut, when I had to drain the radiator for thermostat change. Worked out fine. If it fits, you could use a "T" fitting to install both the sensor and drain pet****, if that's your concern.
  5. 325w
    325w
    We used to stick those in the upper radiator hose under the clamp at the radiator. Your going to turn the knob to where ever you want to turn the fan on. Don't really matter where you put the tube. Thought the pet**** was a good place.
  6. I second that. Near or in the top rad hose.
  7. raj4851
    raj4851
    from Decatur Il
    Hi guys, and thanks for all the good info and experience. I know how I'll go now. Thanks again, Rod
