Technical Coolant leak
Discussion in 'Traditional Hot Rods' started by old trucke, Aug 6, 2024.
  1. old trucke
    old trucke
    from ohio
    Installed an swivel type coolant neck on sb it's leaking antifreeze. Uses o o ring to seal . Used some rtv to try and seal. Are this type neck prone to leak. Trucke
  2. Mike VV
    Mike VV
    from SoCal
    The problem may not...be because of the o-ring.
    I recently bought a car that had one of those. There was no location Machined cutout) for a thermostat to sit properly. I tried installing one, no matter what I did, the damn thing leaked.
    I bought a $!0 OEM style housing...no more leak. AND...the water temp., was more properly controlled with the thermostat in place.
    Mike
    Unkl Ian and RodStRace like this.
  3. RodStRace
    RodStRace
    RTV alone between 2 metal surfaces isn't great at coolant sealing due to it hardening and with temp plus pressures involved. With a gasket will work better.
    An O-ring shouldn't need anything except a bit of lube to allow smooth seating or it's not designed properly.
    You can try other sealers that don't fully harden, but check fitment as @Mike VV mentioned.
    I will mention that between all the different necks and hoses, you should be able to find a solid one unless this is a very special case. It may require a fabricated one.
  4. bill gruendeman
    bill gruendeman
    Check and make sure it’s machined properly, nice and flat
    Unkl Ian likes this.
  5. Mr48chev
    I'm thinking that those had a reputation for leaking or other issues since they showed up years ago. Great idea that would solve some problems if it worked perfect.
    Just Gary likes this.
  6. ***uming this is the same 40 Chev. truck of the last two threads- since you need to install a shroud anyway, I would do away with that swivel, go to a straight neck outlet with a gasket, and use a different upper radiator hose. If the swivel is being used because of interference with accessories, maybe a different outlet?
  7. 2OLD2FAST
    2OLD2FAST
    from illinois
    A SBC intake manifold has the relief machined for the thermostat , IIRC some others have the relief in the thermostat housing .
    I've had this type of housing in use for 20+ years , has been on & off many times . Have never had a problem.
  8. vtx1800
    vtx1800
    I've had mixed results with that type of housing and if I had a choice I wouldn't use them, but...sometimes the application demands a different solution than is available as "stock":( I've filed the manifold to insure a flat surface and on my last engine I used RTV to "lock" the thermostat down because there was too much sloop between the manifold and the housing.
  9. dana barlow
    dana barlow
    from Miami Fla.
    If chrome,yes,or over pulled down. If chrome,sand off chrome were gaskets are,if it been bent,more gaskets or get new one.
  10. Doug G
    Doug G
    from Manheim Pa
    Use a good quality chrome housing like a Mr Gasket from NAPA with the O ring seal only. Do not add any RTV or sealant. Make sure your mounting bolts are not too long, (some are threaded blind holes in manifold). Ask me how I know !
  11. chargin03
    chargin03
    summit gasket SUM- G2399 worked for me.
    2OLD2FAST likes this.
