Technical Coolant leaking from thermostat housing bolt
Discussion in 'Traditional Hot Rods' started by Koolman, Sep 26, 2014.
  1. Koolman
    Koolman
    Hi everyone,
    I have a 50 Mercury flathead with iron heads and thermostat housings.
    I am getting a coolant leak through on the the thermostat housing bolts.
    When I remove the bolt I can see coolant in the bolt hole.
    Is that correct?
    If so, how should I seal the bolt hole? Thread sealant etc.
    Thanks for you help!
    DK
  2. Gasket sealer around the t stat gasket on both sides and some around the bolt threads.
    tb33anda3rd likes this.
  3. Atwater Mike
    Atwater Mike
    Helpin' 'KOOLMAN' stay 'kooool'..... Use black permatex as sealer, gaskets & threads.
    Stay 'Koool'...
    nutbush likes this.
  4. Slopok
    Slopok
    There shouldn't be any water in bolt hole unless they have broken through the head.
  5. Slopok
    Slopok
    However after loosening and removing the bolt may allow water to seep into the threaded hole.
  6. Koolman
    Koolman
    Thanks for the help.
    I am still not sure if I have a leak in the bolt hole.
    I will try the permatex and see what happens.
