COOLEST LOOKING 4-banger you've ever seen..let's see em'
Discussion in 'The Hokey Ass Message Board' started by heyitsnate, Dec 6, 2004.
  1. Here's one of them 'Hisso' engines. About 360 cubic inch, now thats a BIG 4 pot!
    They were meant to be really slow to get wound up, but once they were up and running they were very quick. [​IMG]
  2. Bruce Lancaster
    Bruce Lancaster
    That Hisso car was featured in HRM a couple of issues back, mebbe about 1960.
    I just picked up a 1920's aircraft catalog with Hisso engines and parts (Kaiser war surplus), engines and parts for the big USA V8 airplane engines, and surplus trainer biplanes for $1--2,000, depending on level of condition! The catalog also lists Spun wheel disks in a variety of sizes!
  3.
  4. More slingshot's....
  5. metalshapes
    metalshapes
    A 1500 Shorrock Blown Ford Pre X-flow in a Allard Dragon ...
  6. Flynn's_57
    Flynn's_57
    from Nor*Cal
    Jive-bomber-
    What the hell is that thing?
  7. 'nother 1......
  8. oldchevyseller
    oldchevyseller
    from mankato mn
    how about a hand built 1/5th scale
  9. brjnelson
    brjnelson
    [ QUOTE ]
    Wayne Atkinson, there is a name from out of the past, is he in Minnesota now?
    [/ QUOTE ]
    Wayne is now in NE Iowa. He had some good banger flow tests in Secrets.
    Speaking of Winfields, I will get this on my A this winter.
    I will try to make a manifold out of old broken winfield intakes. I do not want to use the stromberg adapter that is on the carb now.
  10. RenoRat
    RenoRat
    from Oxnard,Ca
    MMM i like that Winfield Carb/Intake....
  11. KSGerry
    KSGerry
  12. KSGerry
    KSGerry
  13. KSGerry
    KSGerry
    OK...how about a four cylinder that uses a V-8 small block head...GM, Ford or Mopar!
  14. KSGerry
    KSGerry
    Same as above but with a Cosworth head having dual overhead cams...
  15. racer5c
    racer5c
    Never been a prettier motor built than a Miller 4 cyl
  16. pikesan99
    pikesan99
  17. BRENT in 10-uh-C
    BRENT in 10-uh-C
    This is my track roadster engine ...
  18. The37Kid
    The37Kid
    This is a SOHC ROOF Head on a B block. I sold it to Doc Pruden in California in 1976. Has anyone seen it recently?
  19. oldcarfart
    oldcarfart
    Toyota 2TC/3TC Hemi engines from late '70's early '80's corolla models.
  20. 50Fraud
    50Fraud
    I had a Lotus Super Seven with an Cosworth-tweaked English Ford 1340cc engine. Twin Weber DCOEs, Isky cam, popup pistons. Not an especially cool looking engine, but it produced something over 100 hp and in a 1000 lb car, it flew!
  21. sgary
    sgary
    Saw this one at the Loafers Old Time drags.It is the fastest and loudest 4 banger I have seen!
  22. GuyW
    GuyW
  23. SDhotrod
    SDhotrod
    Great thread!
  24. RichFox
    RichFox
    If your going to be that way I need to step up for Plymouth
  25. Crazydaddyo
    Crazydaddyo
  26. NINE INCH
    NINE INCH
    You know I LOVE IT!!! Before I ever saw your's, Crazy, After much research, I knew this was the configuration of "A" engine I had to have. Then, while Max(H&H) was building it, I saw yours and knew I made the right move. VERY cool.
  27. NINE INCH
    NINE INCH
    You set the standard high. If mine looks half as good, I'll be a happy Banger Dude.:DB
  28. Crazydaddyo
    Crazydaddyo
    9",
    With all of the shiny bit on yours, once that your's is on the road, mine will pale in compairison. You've taken yours a step beyond.
  29. Niklas sweden
    Niklas sweden
    Hi
    My name Niklas from Sweden and here is my build, its a blower model a engine. I think its a cool looking 4-banger.:)
  30. davesville
    davesville
    crazy thats one supercool banger you got there.cant help wondering how it sounds (hint hint) dave
