cooling fan relay problem?
Discussion in 'The Hokey Ass Message Board' started by bellyjello, Dec 3, 2009.
  1. bellyjello
    bellyjello
    The sensor came in the Jegs cooling fan kit. It comes on At 185 back off at 175. Water boils at 212. I removed the pan from the burner and did the test. I never thought of burping the system. When the car heated up I would pull the sensor wire and ground it and the fan kicks on. Temp would drop to 192 0r so. I would ***ume water is circulating. Both hoses had pressure on them , heater core hoses were also hot. Maybe your right. When I pulled the sensor there was water in the intake but not alot. Burping, Remove the rad cap and run the car and squezze the lower hose...
  2. bellyjello
    bellyjello
    I need some input..... Help..
  3. 325w
    325w
    i drill a 1/8 inch hole in the thermostat. run the engine for a bit then shut it off for a while. are use the radiator leak checker pump and pump the radiator to 10 lbs are so for a few mins.
