Technical Cooling system pressure
Discussion in 'The Hokey Ass Message Board' started by junkyardjeff, Mar 4, 2021.
  1. junkyardjeff
    junkyardjeff
    Is it just newer engines that require it,my 37 Chevy has a non pressure system and a 57 235 and it can sit and idle all day long with a four blade fan and not go over 180. I done some changes to my 55 Ford that has a 351 W that had a 7 pound cap and a factory 5 blade a/c fan that the temp would occasionally creep at idle sitting in traffic bur the changes I done required going back to a four blade fan due to lack of room and it instantly started gettng hotter at idle so I put a 13 pound cap on and I think I solved that problem. I had numerous 60s and older vehicles that the pressure in the cooling system did not seemed to matter and never got hotter idling.
  2. bigdog
    bigdog
    Higher pressure cap raises the boiling point of the coolant so the motor can run hotter without boiling and blowing the coolant out. Higher pressure/boiling point will help stop steam pockets from forming at hot spots in the motor, usually by the exhaust valves, which could help the motor run a little cooler on the gauge.
    firstinsteele and triumph 1 like this.
  3. jaracer
    jaracer
    A pressure cap doesn't change the temperature. It changes the temperature at which the coolant boils.
    Also, if you are determining temperature by the gauge in a 55 Ford, they aren't very accurate. I always determined if an engine was getting too hot by looking to see if it was venting any coolant. My 57 T-Bird will get pretty high up on the gauge in slow traffic and hot weather. However, it never loses any coolant, so I quit worrying about it.
    X-cpe likes this.
  4. squirrel
    If it's an original radiator, and came with a 7 lb cap, you're asking for trouble with a 13 lb cap. The radiator tanks are not designed to withstand that much pressure, and could get bulged and leak.
    Some aftermarket radiators have different tank design, and can take the pressure.
    juan motime, Flat Six Fix and X-cpe like this.
  5. junkyardjeff
    junkyardjeff
    It has a new aluminum radiator and a 13 pound cap is what it was supposed to have in 55.
    Flat Six Fix and squirrel like this.
  6. junkyardjeff
    junkyardjeff
    Might be time for a fan shroud too since the fan sits lower then it did originally.
    Flat Six Fix and triumph 1 like this.
  7. Beanscoot
    Beanscoot
    Rockauto lists six different ones, all are 7psi.
    KJSR likes this.
  8. junkyardjeff
    junkyardjeff
    Local parts store said 13 unless he thought I said 1965,going to try it and see how it does but the gauge quit creeping up for now with more pressure.
  9. Beanscoot
    Beanscoot
    Local parts store also told me my little '90s car used gear oil in the transmission, when it actually takes ATF.
  10. junkyardjeff
    junkyardjeff
    It has a 80s engine that most likely had a higher pressure so I do not think it will hurt it,when it goes back to a Y block I will put the 7# cap back on.
  11. SPEC
    SPEC
    You'r problem is air movement , you need good fan blade and a shroud.
  12. junkyardjeff
    junkyardjeff
    I really do not like the fan I got but not much else will fit without relocating the alternator but do not want to go through that since a Y block will be going in soon and that will fix the fan problems.
  13. Petejoe
    Petejoe
    from Zoar, Ohio
    A pressurized system also prevents some fluid loss vs a unpressurized system.
    A unpressurized system can lose fluid at high speed Rpms.
