Technical Cooling the 32
Discussion in 'Traditional Hot Rods' started by pantodd74, Jul 27, 2023.
  1. pantodd74
    pantodd74
    Okay I know there are threads about this but not exactly what I'm looking for. The SBC is running great. I have a 185* thermostat installed. The gauge stays around 185-190 running down the road. When were in the stop and go it heats up into the 210-220's. There is no shroud. I believe it's an early 65ish mustang radiator in the 32 housing. Do I need to bend some metal and mount it under the front of the radiator to run air across the front or find an actual 32 shroud to cover the back of the radiator around the fan?
  2. inthweedz
    inthweedz
    First question, is the system pressurised ?
    If not pressurised, the 210-220 temp is at the point of boiling and puking water out..
    If it is pressurised, the operating temp can/will raise 3 degrees for every lb of pressure.
    So if your'e running a 13lb cap, the boiling point will raise up to approx 250 degrees, before it releases pressure (boils).
    So the temps your talking about, aren't a problem..
    When I built my 32, I had a radiator out of a (Ford I think???) tractor, fitted in the 32 cowl like it was made for it..
    dirt t, clem and dana barlow like this.
  3. pantodd74
    pantodd74
    It has been burping here and there getting the air out. I have made sure before every usage that the radiator was topped off. I believe it's a 16lb cap. Not sure.
  4. krylon32
    krylon32
    from Nebraska
    Maybe you need to let the radiator seek it's own water level rather than refilling it between each drive?
    Dirty Dug, Tim, Happydaze and 4 others like this.
  5. da34guy
    da34guy
    What Krylon 32 said-
  6. 26hotrod
    26hotrod
    from landis n c
    <<<My cooling situation is the same as yours. My temps run the same as yours. I am running a Griffin aluminum radiator w/ a 7 blade flex fan 1/2 inch from the radiator. I installed a MOON water recovery tank on the front that takes care of the puke problem. Hope this helps....................
  7. X38
    X38
    Trying to imagine that. Isn't it too short?
    Hood or no hood?
    PICTURES!
    210-220 with a pressure cap is not panic stations.
  8. pprather
    pprather
    I suggest a shroud on the rear of the radiator, so the fan draws air through the entire radiator core. That should keep the coolant around 200 max when the traffic is stop and go.
    dana barlow likes this.
  9. dana barlow
    dana barlow
    from Miami Fla.
    Engine bay pic,,and pic of front of engine,showing fan/hose's,an pic of front of rod,are all a big help for those trying to help you.What looks all good to you,may infact have a small thing out of place that others can tell ya about.
  10. metalhead140
    metalhead140
    Agree with all the above. A good general rule is that if it's fine when moving but gets hot when stopped/in traffic, then the primary issue is air flow from the fan. Either need a better fan shroud or a higher output fan. The radiator is capable of cooling the engine with enough airflow, you've proved that by travelling at speed. Obviously check the usual suspects like timing too.
    dirt t and pprather like this.
  11. pantodd74
    pantodd74
    I recently changed the tri power to a single 4 barrel with intake and a protronix flame thrower dizzy. So I did have to top off the radiator after it burped the air from the system. No hood, fan is about an inch from the radiator.
  12. X38
    X38
    Maybe it's the photo, but is there a jamb nut on that hairpin? (frame end)
  13. alchemy
    alchemy
    The fan looks like it’s not too big around, and possibly too far away from the fins, and it’s also one of those flexy fans that flatten out. I could almost guarantee a good shroud would help your problem.
  14. woodiewagon46
    woodiewagon46
    from New York
    By the looks of your picture I can see that you need a shroud. All your fan is doing is blowing around a lot of air and not thru the radiator like it should be doing. Your aim should be to pull all the air you can across the fins for maximum cooling and you're not doing that.
  15. pantodd74
    pantodd74
    Already looking for a fan shroud that will work.
  16. SPEC
    SPEC
    The fan needs to be 1/3 in and 2/3 out of the shroud.
    V8-m and anothercarguy like this.
  17. DueceMr32
    DueceMr32
    I run a 160 in a my 32 Roadster. I have a Z 4 inch core Walker and use a cooling Concept electric fan with their shroud. On my Fordor sedan, I have a Walker 4inch core with a mechanical flex blade fan with a plastic WS-40 Max Air shroud. Again, 160 thermostat. Seating in Heavy traffic, each car may get to 198 degrees but once it starts moving it recover quickly. Also each has a Deuce Factory 15 inch over flow tank attached to the radiators
  18. el Scotto
    el Scotto
    from Tracy, CA
    Dudes have made their custom fan shroud out of cardboard then used fibergl*** resin to make it solid.
    A second layer of resin and matting and she should be good.
    A quick sanding and rattle can black and nobody is the wiser...
    I used those tough blue paper shop towels as matting with great success when using fibergl*** resin to jerry rig a rusty trunk floor in some old hoopty I was daily driving.
  19. G-son
    G-son
    from Sweden
    For more complicated shapes some people have made something like a plywood frame where the edges of the shroud has to go (including a round piece for the fan hole), and then staple stretchy fleece fabric to it. Soak the fabric in laminating polyester and let it cure and you now have a solid base to add a couple of layers of fibergl*** and polyester until you are satisfied with the strength and rigidity, and you now have a shroud with some nice rounded shapes that may even look aerodynamic.
    Just Gary likes this.
