Technical ? Copper fuel fittings
Discussion in 'Traditional Hot Rods' started by wcben, Jun 28, 2023.
  1. wcben
    wcben
    I’m having trouble finding br*** fittings to finish the plumbing for copper fuel lines for my flathead, I just need two 1/4 flare to ford nut (1/2 20) fittings, anyone know a source or have a part number?
  2. deathrowdave
    deathrowdave
    from NKy
    I have few old flare fittings , any chance to get an image ?
  3. wcben
    wcben
    upload_2023-6-28_23-30-23.jpeg I guess I should have mentioned that the fittings are br*** for copper tube, I have a number of the flare nuts as pictured, I need two of the fittings to the left that are ford nut (1/2 20) and 1/4 flare, the one I pictured is 1/4 NPT to 1/4 flare… Thanks!
    Outback likes this.
  4. Try a refrigeration supplies. Looks like a standard 45 degree flare fitting, commonly used in air-conditioning and refrigeration.
    Desoto291Hemi and jimmy six like this.
  5. rusty valley
    rusty valley
    why do you want copper fuel lines ?
  6. McMaster-Carr, we use fittings like that on air brake plumbing on heavy duty trucks. Locally, there is an industrial supply house called Superior Fastener that we use at work.
    deathrowdave, Desoto291Hemi and wcben like this.
  7. wcben
    wcben
    Looking at McMaster-Carr… great listings, thanks! Same problem I’ve found everywhere else, the 1/4 45degree flare is pretty common, the 1/2 20 end that would go into the carb is not… that’s what’s really hanging me up, the carb end.
    Truckdoctor Andy likes this.
  8. 2OLD2FAST
    2OLD2FAST
    from illinois
    Another of those "Ford exclusivity" parts ! You had to buy it from ford ! Is the 1/2-20 part a straight cut thread or tapered ?
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    those are straight thread
    Desoto291Hemi likes this.
  10. carbking
    carbking
    Probably would take 15 minutes to turn one out on your lathe; times 2 - 30 minutes.
    Jon
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    Here’s a picture of the stromberg needle seat
    EAFD15C1-6BEF-45CC-ABEF-5DD614FD7687.jpeg C2DC7CEC-27ED-4B4A-B8B1-BD50961CAE20.jpeg
    Here’s a picture of a hose ****** that screws into it and has a tapered seat
    D614ABE1-0E47-4317-A2F0-67365345D3D4.jpeg 58C9EADC-5044-4F2C-9C40-8F1D23DB171F.jpeg
    Here’s a banjo fitting that seals with a gasket
    438376B4-A4AD-4845-9F36-A8165277FC12.jpeg B0B13158-E951-4B34-A4CB-6A0E6CC4975E.jpeg
    Desoto291Hemi, wcben and Jeff Norwell like this.
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    I dug through my fitting drawer and found a 5/16 flare nut. It screws right on to the 1/2-20 fittings that I have, can you find a union that is 1/4x5/16???
    5CA45DEA-870F-4F63-AE8F-4E798AF48D53.jpeg 64895A22-3AD6-4E26-8BC0-F5067693CC0A.jpeg 0EDA286F-3EA1-4620-8215-0281CD589337.jpeg 7318EF18-854F-4AFB-80E3-2E5DC0D5CE15.jpeg
    Jeff Norwell likes this.
  13. manyolcars
    manyolcars
    they say copper lines will work harden and break. A previous owner ran copper from the gas tank to the carbs on my 1939 Ford that I drove daily for 17 years thru 4 states. It didnt break but very fine copper flakes continuously filled my gas filter. I had to stop on the side of the road many times to blow out the filter so I could continue. I replaced the copper with 3/8 stainless and no more problems.
  14. wcben
    wcben
    If I only had a lathe and the knowledge on how to use it… there’s plenty of material in a couple of the fittings I have to turn them down, just don’t have the means to.
  15. Moriarity
    Moriarity
    SUPER MODERATOR
  16. nochop
    nochop
    from norcal
    IMG_4931.jpeg I found 1/2 straight to 3/8 jic male. Common fitting at your local hydraulic hose shop. You could always bag copper and go jic fittings. Very cost efficient
  17. 2OLD2FAST
    2OLD2FAST
    from illinois
  18. wcben
    wcben
    That one’s so close, not sure about the 5/16 thread on the carb side, all of my research says it’s 1/2 20….tried a 5/16, wouldn’t thread into the carb… upload_2023-6-29_22-33-46.png This one is close except it’s 37 degree, not 45!
  19. nochop
    nochop
    from norcal
  20. wcben
    wcben
    Thanks but that’s a number -6AN - need 1/4 45 degree flare to 1/2 20 (ford or stromberg).
    Johnny Gee likes this.
  21. 2OLD2FAST
    2OLD2FAST
    from illinois
    The 5/16 refers to the tubing size , the thread size is what your after , that I " think" is 1/2-20
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
  23. Moriarity
    Moriarity
    SUPER MODERATOR
  24. wcben
    wcben
    Thanks again, I’d tried a 5/16 as shown, it doesn’t fit upload_2023-6-30_18-0-14.jpeg it’s really close but just large enough and it must be like 18 instead of 20… the fitting above fits perfectly but isn’t 1/4 flare
  25. Moriarity
    Moriarity
    SUPER MODERATOR
    This is a flare nut for a 5/16 and it is 1/2-20 I show it here screwed onto a stromberg fuel fitting the picture you’re showing above looks like a pipe thread fitting to me 1C265E69-7408-40E7-9CFD-6B5571EEE6D9.jpeg
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    Ok, I found the female part of the 5/16 flare this is the same nut I had screwed onto the stromberg fuel fitting
    7F4A05B1-AEDE-4231-94D9-AFA830EB9200.jpeg A8FF0A3A-15CE-46C1-8D89-ADE48F59860E.jpeg
    Here’s that fitting screwed into a stromberg 97 inlet ( needle seat) fitting. It is 1/2-20 1AA52E17-12E5-453B-AE39-1EAB79BEE534.jpeg B5D9D2C8-CD73-4987-B057-EE5FF2372DA1.jpeg
    wcben likes this.
  27. wcben
    wcben
    That’s the frustrating point about this whole thing, the 5/16 flares that I have will not thread into the carb.
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    the picture you showed looks like tapered pipe thread to me
    Bandit Billy likes this.
  29. wcben
    wcben
    5/16 flare… as per Strombergs site the regular 97 needs 1/4, the big 97, 5/16 so… I picked up some 5/16 to go from the mechanical pump to the distribution block that is part of my manifold, wanted to go 1/4 from the block to the carbs… everything is good except for these last fittings at the carbs. I have 5/16 45degree flare fittings (both male and female), and the males definitely do not thread into the carbs, the fittings I showed were a 1/2 2o that I pulled off a carb and a 5/16 flare to 1/4 NPT that was an extra…the 1/2 20 will thread into the female 5/16 flare nut but the 5/16 male flare will not thread into the carb.
  30. X38
    X38
    Good grief! How does anyone plumb these things, it sounds like a nightmare. :eek:
    rusty valley likes this.
