Copper fuel lines???
Discussion in 'The Hokey Ass Message Board' started by adavis, Feb 26, 2014.
  1. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    Try this:
    <table width="100%"><tbody><tr><td width="33.333333%">[​IMG]
    FEDERAL HILL TRADING COMPANY
    </td> <td width="33.333333%">OEM suppliers since 1995 in small bore hydraulic tubing for automotive and light truck brake applications.
    </td> <td width="33.333333%">OUR PHILOSOPHY
    "Lasting value is built with
    quality products and expertise."
    </td> </tr> </tbody></table>
    <table id="ctl00_columns" cl***="page-body-columns" style="border-collapse:collapse;" cellpadding="0" cellspacing="0" border="0"><tbody><tr><td id="ctl00_leftColumn" cl***="page-column-left"><nav> Products
    Links below contain tubing and the nuts and fittings for that size tubing
    British-Girling Fuel/Hydraulic/Brake Line Tubing, Nuts and Fittings
    3/16"/4.75mm Brake Line Tubing, Nuts, and Fittings
    1/4" Brake Line Tubing, Nuts and Fittings
    5/16"/8mm Fuel/Hydraulic Line, Nuts and Fittings
    3/8" Fuel/Hydraulic Line, Nuts and Fittings
    1/2" Fuel/Hydraulic Line
    6mm Brake Line Tubing
    10mm Fuel/Hydraulic Line, Nuts and Fittings
    12mm Fuel/Hydraulic Line
    Bleed Screws, Banjo Bolts and Misc. Hardware
    Flaring Tools
    Flaring Tool Rental
    </nav> </td><td id="ctl00_centerColumn" cl***="page-column-center"> Home > 5168mmdirectory
    <table cl***="content " style="width:100%;" cellpadding="0" cellspacing="0" border="0"><tbody><tr cl***="content-top-row"><td cl***="content-tl">
    </td><td cl***="content-tp">
    </td><td cl***="content-tr">
    </td></tr><tr cl***="content-body-row"><td cl***="content-lt">
    </td><td cl***="content-body"> 5/16"/8mm
    FUEL/HYDRAULIC LINE, NUTS, FITTINGS AND TEE'S
    </td></tr></tbody></table></td></tr></tbody></table>
  2. unkledaddy
    unkledaddy
    From the Hamb in 2005;
  3. Fortunateson
    Fortunateson
    CuNiFer: Cu=Copper, Ni=Nickel, and Fer= Iron
    So it's an alloy that has a lot of great benefits.
  4. inliner2318
    inliner2318
    from Tyler, TX
    The way they make fuel line nowadays, copper is better even the thin wall stuff. I had "fuel" line start dripping and went o grab it and the outer sheath of the hose came off.
    I like swagelock stainless tubing. very ridged and clean. fittings come in 1/4" NPT to 1/2" NPT and bigger. Nice tight sealing, stainless, almost like chrome. won't crush. bends fairly easy. Buy a stainless tubing cutter though! Oh and good for 5000 PSI. :)
  5. CuNiFer is recommended for brake line, so it sure as hell should work for gas line! Copper does look cool, but it does have a risk, why play with fire? (literally)
  6. Texas57
    Texas57
    I'm running the nicopp 3/8 lines along the frame, with connections to airquip teflon s.s. flex lines with -6an fittings at the engine and tank. What is the best type of fitting to use on the nicopp line to attach to the airquip flex hose fittings?
  7. Texas57
    Texas57
    I guess I should have asked if flared fittings are prefered for the nicopp lines or compression fittings. I've found both.
  8. Couldn't you copper plate your steel lines?
    Steve
  9. '51 Norm
    '51 Norm
    from colorado
    I am a fan of Swageloc fittings and have been using them at work for many years.
    The fittings come in every imaginable size and type in both stainless and br***. I have been known to polish the stainless ones and they look great.
    I currently have some polished stainless fittings on a Pontiac tri power set up; I'll have see if I have any pictures of it.
    The only issue I have with them is the price, they can be pretty spendy.
    And yes they are good to several thousand PSI. The factory reps used to do a demonstration where they would pressurize a piece of tubing with a Swageloc end on it. The tubing would burst before the fitting leaked, pretty amazing.
  10. bchctybob
    bchctybob
    I just went to ACE hardware and got 5/16" copper line, no idea what it is, specifically. I coiled it around a mandrel, flared it and connected my 3 deuces to the fuel log. The feed line from the mechanical pump to the fuel log is the same, formed to follow the contours and to look nice coming up from below. It's been on there for years with no problems. And yes, it gets driven.
    I think the problems arise if you let 'em flop around or try to run them between two points that can move independently in relation to each other such as from the frame to the engine.
    I always liked the polished copper fuel line look and it's been on all my street cars since high school with no problems.
    *****in' Caddy Dreddybear!!!!
  11. WOODEYE
    WOODEYE
    Like 51 Norm, I am a fan of the Swagelok brand of compression fittings too. They are very forgiving and always seal without having to put a lot of arm into them. You can take them apart and put them back together endlessly and they will seal up every time. On fuel lines I like using the 3/8 SS / .035 wall tubing. I also have used these fittings in our work for the last 30ty plus years. Pricey?? You get what you pay for. Fuel leaks can be really costly.
  12. Texas57
    Texas57
    Thanks for the references..I'll look for the swagelok fittings.
    Halibrandsteve...I'm not sure if you were making that reference to me, or the previous posters who talked about using copper tubing. Nicopp is totally different than copper, one of the reasons I like it so much is the copper tint it has when new totally dissapears when polished...looks more like chrome or polished stainless with very little effort. All of the advantages of stainless tubing without the disadvantages (excepting price). BTW, Summit has, or had last week the 3/8 on sale for 50. ish per 25' coil. Summit has their own brand, not the NiCopp brand, so you'll have to search for nickle-copper tubing . If you search for NiCopp, nothing will come up.
  13. Not a comment to anyone specifically, just curious if the "look" of copper would be better achieved by plating a known, safe material for lines like steel.
    Steve
  14. gimpyshotrods
    gimpyshotrods
    Yup, but that takes the fun of gambling against a fuel leak, on a hot engine, out of it.
  15. Hitchhiker
    Hitchhiker
    Its called Cunifer...
  16. check out the indian motorcycle burn to the ground on u-tube. it had copper lines. the key word had. i talked to the rider after it happened. he said the line cracked and fuel ran down on the engine. find another way to make your car look cool. a word to the wise should be sufficient.
  17. adavis
    adavis
    So I found the heavy wall 1/4" copper line I was looking for at the local refrigeration repair shop. It was removed from an old refrigeration unit and is 5 times heavier than any of the new stuff I was finding at the hardware stores. The stuff looks great, but after reading a lot of the comments I'm concerned that it isn't the right choice.
    Can someone please explain why heavy copper isn't safe? I mean if its installed correctly, why isn't it safe. I'm no metallurgist, but in my mind I would think the copper would be able to "flex" rather than break under stress. Yes, vibration would work harden copper but wouldn't that occur with any metal? I'm running the stock model B mechanical fuel pump (which puts out 3 pounds of pressure) so bursting isn't an issue.
    Obviously I don't want to blow up, but I just want to make sure that I'm not getting rid of copper lines because there's a 1 in a million chance it will fail. I got lots of stuff on my car that are less safe than that.
  18. Blue One
    Blue One
    from Alberta
    :rolleyes: Cunfier is NOT plated steel tubing :rolleyes:
  19. Hitchhiker
    Hitchhiker
    You're right. Its much better.
  20. Blue One
    Blue One
    from Alberta
  21. I thought someone mentioned it looks more like stainless than copper though?
    Steve
  22. Blue One
    Blue One
    from Alberta
    That may well be the case, however if I was dead set on the visual appearance of copper I would fab my lines from the safer material like Cunifer and then have them plated with copper.
  23. Morrisman
    Morrisman
    from England
    In the UK we are allowed to use copper tube for brake lines, so pressure is the least of your worries. ;)
  24. adavis
    adavis
    Ok, so why is HEAVY WALL copper so dangerous?? If it's mounted correctly and has a coil for vibration why is it not safe?
    Sent from my SCH-I535 using H.A.M.B. mobile app
  25. coryw
    coryw
    from Omaha, NE
    Morrisman,
    Are you sure it isn't a copper alloy? Copper alloy is the cunifer / copernic, etc. discussed above as being superior to straight copper.
  26. Hitchhiker
    Hitchhiker
    Work hardening.
    Cunifer is a alloy. It is more malleable than straight copper. Meaning it takes longer to work harden. Thus less chance of it developing a crack.
  27. Hitchhiker
    Hitchhiker
    I haven't received mine yet....but it looks like copper in pictures.
  28. adavis
    adavis
    Ok, so I can understand that, but is this really a danger? I mean I understand that a crack would be a danger, but realistically how much chance is there that heavy wall copper will crack? I say this ***uming that the lines are installed correctly. What I'm getting at is that if Cunifer will last me 150K miles and heavy wall copper lines will last 120K miles I don't think its enough to worry about. After talking to a few refrigeration guys it seems to me like heavy wall copper has been used in refrigeration units for a long time and they are not only subject to continuous vibration but also extreme pressure and don't fail for decades.
    I'm not trying to purposely be unsafe, I just want to understand why some people are completely against copper. If copper is a ticking time bomb that could break easily I will re-do my lines with Cunifer, but if copper will last 100K miles then I'll risk it.
    Thanks again for all the input and advice.
  29. fsae0607
    fsae0607
    I think if you secure your lines well to prevent movement, I don't see why it would be a problem. What about copper lines used on 3x2 setups back in the day? Someone concur?
  30. Ramblur
    Ramblur
    Mercedes powered Fokker D-VII coming back together.
