Cornhuskers T-5 adapter kit to flathead
Discussion in 'Parts For Sale' started by skinnydennis, Jan 7, 2021.
  1. skinnydennis
    skinnydennis
    from Austin, TX
    City: Austin
    State: TEXAS!
    Price: $650.00
    Selling my Cornhusker's T-5 to flathead adapter kit. Also listed with the kit is a Fort Wayne 10" diaphram which has the ends of the fingers cut off as needed to fit this. The ones you buy you will have to do this yourself and it's not that easy. Fort Wayne is the best there is. Also included is a Speedway 10" clutch plate and the Slave cylinder kit from Cornhuskers the you will need to install this kit. So what is included is:
    1. Cornhuskers aluminum bell housing. I notched out for the starter cup (necessary as they don't come this way.
    2. Throw out bearing ***embly
    3. Pilot bushing for flywheel
    4. Throw out bearing fork
    5. Return spring (attached to bellhousing by me) not done by Cornhuskers
    6. Lower clutch shaft
    7. Instructions
    8. Slave cylinder kit (Wilwood 7/8" master also)
    9. 10" clutch plate
    10. Fort Wayne 10" pressure plate.
    What does not come with it is the 4 allen head bolts to bolt the transmission to the bell housing. These are easy to get at any good fastener company. Also a few hydraulic fittings and metal hydraulic line that you will need to fabricate.
    All totaled these parts exceed $1,100.00. Text Skinny @ 512-970-1319
