Coronet 440 Convertible
Discussion in 'Cars For Sale' started by schillaz, Feb 28, 2019.
  1. schillaz
    schillaz
    City: Makoti
    State: North Dakota
    Price: 7000.00
    Dodge Coronet recently pulled out of storage. V8 Auto car. Complete fuel system flushed and upgraded with new tank/sending unit and pump along with carburetor. Entire cooling system flushed and replaced water pump and radiator. Complete brake job including all new pads and hardware inside, drums have been turned.
    It's just been too cold and too much snow in N.D. for the final test drive so i'm sure there some bugs still needing to be worked out.
    It will move on its own power gears seem to work forward and reverse.
    Compression test was good on all cylinders. Starts and runs smooth. Top works up and down.
    Body and interior is OK, I would one day replace with red interior and new paint. Has dings dents and imperfections.
    Clean ND title in hand.
    Things already done:
    New Radiator
    New Fuel tank
    New Tires all the way around
    Ignition lock
    Ignition switch
    Trunk lock
    Horn ring
    Radiator
    Master cylinder
    wheel cylinders
    hydraulic hoses (front)
    belts
    radiator upper hose
    radiator lower hose
    transmission filter/gaskets
    brake pads (4 sets)
    wheel seal (2 front)
    drum brake hardware kits
    drum brake adjusting screws
    hydraulic hose (rear)
    oil & oil filter
    Carburetor
    fuel pump
    fuel filter
    water pump
    time chain
    thermostat
    coolant
    Transmission fluid
    Transmission filter
    Things Left to do:
    Rear window
    Exhaust
    Drive to adjust new brakes
    Fine tune
    fwi and biggeorge like this.
  2. schillaz
    schillaz
    New driver side window is installed, mark that off the list.
    Still up for sale.
    Make me an offer.
  3. schillaz
    schillaz
    Price lowered................
    fwi likes this.
  4. schillaz
    schillaz
