Correct bodywork process?
Discussion in 'The Hokey Ass Message Board' started by chris101_ny, Mar 23, 2012.
  1. chris101_ny
    chris101_ny
    I,ve been doing a driveway job on the bodywork. Is the following right? Strip to metal, apply and shape fibergl***, apply and shape bondo, primer, skim coat, primer again. i've been reading a lot and its all over the place! Any thoughts?​
  2. squirrel
    replace "apply and shape fibergl***" with "weld in metal" and you've mostly got it
  3. Da Tinman
    Da Tinman
    how bout some pics of what your trying to fix? Gl*** over gaping rust holes isnt going to last.
  4. joeb1934
    joeb1934
    i do body work for a living, and it is okay to use 'body filler' (sparingly, and only if the primer is prepped properly first) over primer. it's better to use body filler in direct contact with metal, but it can be done. unless you were building custom speaker units, i wouldn't recommend the bondo over fibergl*** path. fibergl*** doesn't bond well with metal, and the repair would not last.
  5. 49ratfink
    49ratfink
    are you working on a Corvette?
  6. moparmonkey
    moparmonkey
    from NorCal
    Seriously!
    Fibergl*** and metal do not go together. Ever. So, unless you're working on a fibergl*** body, don't put fibergl*** on your car. Weld in patch panels, hammer and shape with a dolly, stud puller, sledgehammer, whatever. Just not fibergl***. The fibergl*** won't stick, the metal will keep rusting, and the bondo will fall off. And you (or the new owner who will curse your name to the 5th level of hell) will have to repaint the car.
  7. 2-TONED
    2-TONED
    as soon as 'bare metal is exposed to air its rusting!
  8. Rusty O'Toole
    Rusty O'Toole
    You need to sand or grind off paint in areas that are to be welded or bondoed. Not otherwise. If the original paint is on there good, not rusted, leave it and paint over it. Now if the car has had 4 or 5 paint jobs you don't have much choice. But if it is only the original factory paint, just sand it and paint over it.
  9. cherokee_64
    cherokee_64
