Corroless Anyone?
Discussion in 'The Hokey Ass Message Board' started by Fortunateson, Jun 26, 2012.
  1. Fortunateson
    Fortunateson
    Does anyone have experience with Corroless? I have an un-opened can I got from Eastwood years ago. Kept in cool ba*****t. Do you think it would be OK?
  2. marxjunk
    marxjunk
    from KCMO
    as long as it isnt chunky it will be fine..if it pours out like jelly its done
  3. Fortunateson
    Fortunateson
    I wouldn't be able to thin it out? And have you used it? I want to know how it stands up to other, similar products.
  4. chubbie
    chubbie
    yes i used it and like it, I brushed it and thinned it and sprayed it
  5. marxjunk
    marxjunk
    from KCMO
    i used it for years, and i really like it..but if its bad, as in chunky and jelly...its lost its stuff, and by thinning it down it will peel, and thats bad if its uner paint or filler..
    any time i welded anything together i used it like DP40 epoxy, but, i liked it better...i used and acid brush and dabbed both sides..then worked filler right over it, and never had a moisture problem, a couple cars are 10 years since done and held up well. i also used it thinned down and sprayed it on the bottom of chevelles, looks like factory sealer...
    i cant say enough good things about it...good stuff
