Corvair IFS Ideas
Discussion in 'Off Topic Hot Rods & Customs' started by 32 Confederate, Jun 22, 2025.
  1. 32 Confederate
    32 Confederate
    I am working on setting up a Corvair IFS for my street rod project here is the Idea list thus far:
    conversion of corvair hubs for 32.... Machine OD of hubs to accept S10 4x4 rotors
    replace 7/16" x 20 / 0.472 Knurl wheel studs with S10 4x4 M12 X 1.5 /0.501 Knurl
    Replace wheel bearings and races
    design caliper mounting backplate for either S10 4x4 dual piston calipers or
    Speedway Metric calipers with oversize pistons
    https://www.speedwaymotors.com/2-3-4-Inch-Big-Bore-1978-88-GM-Metric-Brake- Caliper,25158.html
    My question is, has anyone done a rear mounted rack and pinion conversion on one of these and if so, would you share specific details on how to best do it to avoid bump steer?
  2. BJR
    BJR
    Why?
    Deuces and 49ratfink like this.
  3. 32 Confederate
    32 Confederate
    Wanting to do something different and keep it as much Chevrolet as I can.... Dad was a dealer mechanic in the late 50's until the mid 60's... I already have a rebuildable corvair IFS, but someone put a front mounted R&P on it that would interfere with the front splash apron and was not well thought out...
  4. 32 Confederate
    32 Confederate
    Another reason being that it will make repair parts more available as my son and I have several S10's and then I could basically get all of the parts for a brake job under a single vehicle reference that would be readily available at most parts stores when on a trip.
  5. RodStRace
    RodStRace
    To expand a bit on the question @BJR asked, why?
    Negatives
    It's an old design for a rear engine car.
    It was done to rods back in the 60s, but had fallen out of favor a decade later.
    It requires a lot of work and modification.
    I would imagine that there are a lot of more refined, modern designs that have better geometry, easier parts availability and easier installation. Even if you limit it to GM offerings, the obvious answer is Corvette upper/lower arms and spindles for 5 generations, along with various other platforms. You just mentioned S10. Why not use those parts?
    https://autoctrls.com/wp-content/img/chevy-s10-front-suspension-diagram-dxv.jpg
    Positives
    Different - not really. As said, it was done back in the day.
    It sounds like what you are working on already has it, but poorly done. Fixing may be less work that replacement, but that's your call.
    BJR likes this.
  6. 32 Confederate
    32 Confederate
    All very good points..... I am working on a limited budget as we all are.... it also is one of the few designs that will allow the front fenders to remain in their original configuration. I thoroughly appreciate your insight and opinion.... I am still in the planning phase and believe that the M2 took over dominance in the market due to the demise of the corvair due to Nader's raiders and thus the limitation on parts....
    SS327 likes this.
  7. RodStRace
    RodStRace
    Hey, I appreciate that it was taken in the mindset it was written. We all have budgets to work within too!
    While the MII has become the basis for most modern stuff, it's also pretty old.
    I'm no engineer or CAD/CAM guy who can model the parts and compare, so I can't guide you with valid points on a better choice. Darn near everything built in the past 20 years is heavier than most rods are, so I wouldn't even know which are a good starting point. I'd want to avoid any strut, multi-link and one-off (expensive, hard to find) stuff, but it also comes down to adapting to the typical C channel or box frame rail and as you said, cost. Add in packaging for early fenders you mentioned and it's the needle in the haystack.
    If the Corvair fits, works, and will be cheaper and easier than others, go for it.
    32 Confederate likes this.
  8. BJR
    BJR
    I had an Olds powered 34 Ford back in the late 60's that someone had put a Vair front end in. It understeered something awful. If you went around a corner fast the front tires would slide. Replaced it with a stock Henry front suspension and all was good.
    49ratfink and 32 Confederate like this.
  9. pprather
    pprather
    I drove a full fendered 31 Ford Victoria for many years, over 140k miles, with the 2nd generation Corvair front crossmember, suspension and brakes.
    As noted the front steer rack interferes with the splash apron.
    At about 40k miles I converted it to rear steer, to improve the front end appearance.
    The conversion was not difficult.
    I used an Omni K-car rack. I swapped the bolt on steering arms, from side to side. The steering radius was too large, so I was able to get the performance, shortened steering arms. That helped a lot.
    I also swapped the wheel cylinders, side to side, so the brake line pointed to the rear.
    I never had a problem with the adequacy of the drum brakes. Tire wear was never a problem. Bump steer was never a problem
    I had to replace the brake shoes once while in Vermont ( I live near Chicago), in the early 2000's. Stopped at the NAPA store. He asked if I wanted the cheap ones or the better ones. He had both in stock, no one stock anything these days.
    Corvair parts are still available from Clark's Corvair in Manchester, NH.
    https://ssl.corvair.com/user-cgi/main
    I hope this helps.
    RMR&C, leon bee, 49ratfink and 5 others like this.
  10. TrailerTrashToo
    TrailerTrashToo
    Quick correction:
    "Clark's Corvair Parts, Inc.
    400 Mohawk Trail Shelburne Falls, MA 01370 USA"
    leon bee, 32 Confederate and pprather like this.
  11. 32 Confederate
    32 Confederate
    Thank You! Saving these items to my notes! As far as brake upgrade is concerned, I will be contacting these people for caliper mounting plates to adapt the metric calipers and s10 4x4 rotors: https://www.levairperformance.com/mechanical-and-engine
    leon bee likes this.
  12. RodStRace
    RodStRace
    Great post, @ekimneirbo . There really isn't much room on an early fendered car, let alone have it all be in proper orientation.
    ekimneirbo likes this.
  13. RodStRace
    RodStRace
  14. mustangsix
    mustangsix
    How narrow does you front track need to be? An MGB has a bolt-on cross member and rack and pinion steering. The spindles use the same A6-A2 bearings as early mustangs and Camaros so you could use those hubs or a wilwood hub.
    But the track is pretty narrow, only about 51" hub to hub. They also have an integrated shock/ upper arm. That saves a little space but it's different.
    Rebuilding one only takes $20 of bushings.
    32 Confederate and Ned Ludd like this.
  15. Paladin1962
    Paladin1962
    Can someone post a pic of a corvair front suspension unit? I think I have one that was used to rat up my '57 Morris. I saved it (so far, anyway) just in case someone wanted it. I'm just not sure it's actual corvair. The steering box looks like corvair....
  16. pprather
    pprather
    @In_The_Pink can you share a photo of your Corvair front before installation ?
  17. In_The_Pink
    In_The_Pink
    *my ears ringing, a month later*
    Right here: https://www.jalopyjournal.com/forum...52-rambler-wagon.1291532/page-5#post-15121872
    I did a deep dive regarding setting up the steering with my LM (late model, '65+) Corvair front suspension-- Ackerman, etc., but it's a deep rabbit hole, and I have no room to mount the steering linkage components at the rear, so I didn't dive too deeply.
    I suppose like any cl***ic vehicle, you can take it as far as you want, but I will add this: I did the "Blazer" front brake upgrade (basically adding bolt-on hubs, separate rotors, and dual piston front brake calipers) on my DD '98 Sonoma 2WD and I have zero regrets, so I would think it's be a great upgrade for an LM Corvair front suspension. I would probably go that route versus the Metric single piston calipers if both were similar in cost and complexity.
    Scarebird used to offer bolt on LM Corvair disc brake adapters, but I think they have been discontinued for a few years now. The Corvair forums have plenty of folks who have been down this road already, so it'd be worthwhile IMHO to visit there and spend some time searching and reading.
  18. larry k
    larry k
    OH MAN , that car will handle just like a safe in a wheelbarrow !!!
    49ratfink likes this.
  19. Okie Pete
    Okie Pete
    Put a straight axle under it and build a g***er
    Just ignore me . I’ve been in the sun all day
  20. Hubnut
    Hubnut
  21. RodStRace
    RodStRace
    Okie Pete likes this.
  22. 32 Confederate
    32 Confederate
    You guys are GREAT! Still doing research as the job/commute/life, never allow the time I'd like to dedicate to the projects.... seem to have fallen behind on my chores around the house while I was down for 4 1/2 months for eye surgery on both eyes.... keep the ideas coming... I'm still kickin'!
  23. 42merc
    42merc
    In the very early '70's I put 2nd gen Corvair fronts under a '34 Ford cpe & a little later an " A" delivery. Used front mounted Pinto R&P with shortened arms on both.
    Drove well, steered well.
    Worked for me.
    An after thought : Springs, got with the local GM parts guy and sourced a heavier Corvair spring, worked good with SBC engine weight.
  24. 32 Confederate
    32 Confederate
    So much for "OH MAN , that car will handle just like a safe in a wheelbarrow !!!"
  25. Dick Stevens
    Dick Stevens
    If you don't have anything intelligent to add to the conversation, don't be a jack*** and keep your snarky commnets to yourself!
  26. 32 Confederate
    32 Confederate
    Think I may have figured out a decent home grown disc brake conversion using S10 ZR2 components and some fabricated mounting plates:
    https://www.speedwaymotors.com/2-3-4-Inch-Big-Bore-1978-88-GM-Metric-Brake-Caliper,25158.html
    Planning on rebuilding a S10 Blazer 4X4 disc brake rear with an Auburn Posi to give me the proper track width and use the ZR2 rear disk brake package... anyone have a good idea for a decent performance/cruising gear ratio for this? I was thinking something in the 3.31 to 3.55 range with quality axles and a girdle/truss style cover....
  27. 19Eddy30
    19Eddy30
    from VA
    Corvair front , done in 1986 ,
    1991 over 150 Orlando Speedworld
  28. HOTRODPRIMER
    HOTRODPRIMER
    <----- The Model A pickup was built in 1970 and I used a Corvair front suspension including the drum brakes and swapped the spindles from side to side and mounted it backwards, I also use a Colt rack & pinion,a shortend GM steering column and hooked it up with a pinto flex shaft, I built the entire truck with parts from the junk yard, the truck handled like a dream and absolutly zero bump steer.
    There are far better components avalible today, but use what you want, if you are shooting for a traditional car I would use a dropped axle but it's your car,build it your way. HRP
