corvette valve covers?
Discussion in 'The Hokey Ass Message Board' started by kustomkoupe, Feb 3, 2005.
  1. kustomkoupe
    kustomkoupe
    i just traded my 32 rear corssmember for a nice set of corvette valve covers...
    does anyone know what years had the lower writing on them...the word corvette is barely sticking up as opposed to some where it sticks up maybe 1/8-3/16 inch...they are staggered bolt...
    our 32 coupe race car had a '62 327 (in '62)...will these fit that? it was a brand new motor...rare i guess for dirt track cars
    i got the guy a pair of ratty 32 rails and he gave me good lever shocks for my roadster just cause i got him the deal
    so if anoyone has any info on the vette covers id appreciate it
    thanks alot
    zach
  2. I believe staggered is 58 back, I have only one I think it was off a 58???
  3. Lionheart
    Lionheart
    _________________________________________________________________________________
    The staggered hole were used from '55 to mid '59. I don't know what years the low script was used though, but i would guess the earlier ones, maybe 55-56.
  4. Rand Man
    Rand Man
    Staggerd bolt pattern was on the early heads for the 265. The 327 heads had the sqaure pattern.
  5. CLSSY56
    CLSSY56
    Are they stagger bolt covers? If so they are 55-58... Here is mine on a '56.
  6. superchargednailhead
    How many fins some on them. They made them with 7 fin and rare 9 fin.
  7. JohnnyB327
    JohnnyB327
    believe it or not they made an 11 fin too
  8. superchargednailhead
    I have seen a pair of 9 fin but i never knew they made a 11. Do you no what they came on?
  9. JohnnyB327
    JohnnyB327
    I've been searchin for that answer for many months.
  10. fab32
    fab32
    The covers you have with the staggered holes will not fit '62 heads.
    Frank
  11. PurHell
    PurHell
    from So Cal
    Ya ... But I think there worth big $$$ to the resto Vette guys ...
  12. JimA
    JimA
    They actually bring less money (unless they are 9 fin) because they fit fewer vehicles. They sell for $50-$100 a pair on ebay.
  13. willowbilly3
    willowbilly3
    from Sturgis
    The staggered hole ones won't bring as much on ebay, which kind of shatters any myth they are worth more to anyone. Unless you just happen to get two determined bidders at the same time. They actually changed to straight holes in the middle of 59. Some early 59s still have staggered holes.
  14. Deuce Roadster
    Deuce Roadster
    True.........Feb. of 1959 to be exact was the changeover.
    Here's a pair of 7 fins......on my old 40 Ford with 283. I have a set of 9 fins too, but have never seen/heard of this 11 fin stuff before.
    Be nice to see a photo ............. :eek:
  15. Boones
    Boones
    from Kent, Wa
    Staggered hole valve covers bring no money.. You can buy a sets on ebay for less then 100 and probably in the range of 50-75 unless they are pristine condition.. but in general they go for half of a straight pattern
    Same with the chevy script. worth half of the standard pattern..
  16. CLSSY56
    CLSSY56
    Paid $65 on ebay for mine.. but they were mis marked ;) they usually go for $75-$150 depending...
  17. reborn55
    reborn55
    Some of those valve cover actually had higher fins than other ones. Don't know why but were found that way on either style.
  18. kustomkoupe
    kustomkoupe
    thanks everyone...heres a picture...7 fin staggered....guess i'll save them for a 283 or something...no big deal..traded them for a crossmember i'll never use...good wall hangers if nothign else and take of less space then that 32 crossmember
    thanks
    zach
  19. briggs&strattonChev
    briggs&strattonChev
    I always wondered why you couldnt just fill a hole on the staggered pattern and redrill a straight pattern, but just noticed that the sides are dimpled. Thanks for shattering my dreams........................
  20. kroozn1
    kroozn1
    I paid $100. N.O.S in the box for my 283.
    Had a pair of 9 fin in rough shape with a chunk of fin missing I got $300 for.
    Carl
  21. 3bytheknee
    3bytheknee
    from Sonora, CA
    Deuce Roadster,
    Is that plate under your carb a heat shield? Just curious.
    Thanks,
  22. tommy
    tommy
    I sure would like to see a picture the 11 finners.
  23. Robert
    Robert
    I believe the 11 fin covers only came on the 1957 FI Corvettes.
  24. Slag Kustom
    Slag Kustom
    you can buy valve cover spacer that will bolt stagered covers onto square heads for about $50
