Could Nitrous be Traditional?
Discussion in 'The Hokey Ass Message Board' started by castanonkustom, Aug 15, 2009.
  1. I've heard about fighter planes using Nitrous during WWII to get more power during take off, and in high altitude situations. Nitrous didn't get used in racing until the 70's. But someone could of used it during the post war, the technology was around but probably not applied to hot rods. If hydraulics were brought from planes to cars it could be a possibility. Any thoughts on nitrous being traditional.
  2. FiddyFour
    FiddyFour
    just because something was in exsistance, does not make it traditional. if you're trying to validate using a nos system in your car, stop. it wont fly
  3. spiderdeville
    spiderdeville
    from BOGOTA,NJ
    smokey yunick started using [legal additive ]nitrous oxide in qualfying in 1952 in the 7X hudson hornet
  4. Not trying to run nitrous i just thought it's an interesting concept.
  5. Very cool do you have anymore info? Or maybe a link?
  6. Dreddybear
    Dreddybear
  7. metalshapes
    metalshapes
    From what I've heard, he had the bottle under the seat, with a hose running to the mouth of the carb.
    ( and running very rich, probably...:D )
    And he just opened up the bottle for a while for extra power.
  8. Little Wing
    Little Wing
    from Northeast
    I would say it could be,,though back then the delivery system would have been different,,so IF you were going to do it,,it would have to be based on how the airplanes did it
  9. mickeyc
    mickeyc
    I knew a certain stock car racer from the sixties who had a military background which is where he learned about nitrous. A tube in his
    roll cage had fittings to receive a limited amount of nitrous under pressure.
    During qualifying he would crack a hidden valve and just turn it loose under the hood at the fastest point of his lap. No gasoline was added , nor was it metered in any fashion. When I questioned him about this, he replied, "Son that 427 (Ford) had no problem finding the gas and it was good for
    about 2 or 3 mph at the end of the straight. He said he got the nitrous from a friend in the bottled medical gases business, since most people had never heard of the stuff. MickeyC from the bayou
  10. I think a couple years ago there was picture of Barney Navarro in the rodders journal with a military nitrous bottle mounted on top of a set of carbs. Said it didn't work very well though.
  11. spiderdeville
    spiderdeville
    from BOGOTA,NJ
    it is in smokey's book
    he told us the story at the 99 SEMA show
  12. squigy
    squigy
    from SO.FLO.
    if you hide it who will know..
    just like they did back in the day!
  13. publicenemy1925
    publicenemy1925
    from OKC, OK
    Marvin Miller was the first system I seen back in the 80's but that is not very old.
  14. I got one of those systems laying around,pretty simple stuff: Dual 1 inch plates made in aluminium,no jets the metering is in the solenoids (small ones can't flow nitrous for more than 125 hp on dual plates).
    But it's of good quality,these things isn't used in more than 20 years but a couple of months ago I did try them out in the shop,and they worked perfectly : open and closed as they should and there was no leaking of neither nitrous or gas throug the solenoids and if it should start to do so it's easy to pick them apart and overhaul them.
    I think I will try it on my inline 6 sometime but only with a single plate,or maybe stack them on top of each other could be fun "for 3 seconds only".
  15. 49ratfink
    49ratfink
    if you buy a kit from summit no. if you engineer and design your own setup using only vintage parts then still no.
    a handful of people using it in the old days does not make it traditional
    this is as lame as the traditional air bag debate
  16. Pir8Darryl
    Pir8Darryl
    Everything's traditional... ABS, EFI, even air-bags were invented, and installed on cars pre '64.
    That still doesn't make it right for our kind of cars.
  17. Little Wing
    Little Wing
    from Northeast
    wait a second,,if it was around and few did it as folks building hot rods,,done the right way it could/would be period correct..or does traditional mean,,accepted by teh masses ??
    if it were'nt for some far out ideas back in teh day,,we would'nt have alotta cool stuff, now,,I mean look at blower evolution
    Nitrous as we know it now ?? NO of course not,,but something taken from a ww2 plane,,sorry I have to say yes,,if your gonna use the the damn seats then the rest of teh plane is fair game as well
  18. publicenemy1925
    publicenemy1925
    from OKC, OK
    I still have the plate off of the one we ran on our v8 vega. It worked really well and like you said it is simply built which always appeals top me.
  19. DMFB
    DMFB
    Uhmm....since when is traditional based upon what was acceptable by the masses? (As stated by Little wing). I say if the technology was around....and you fab it to work (I agree with not buying a kit from Summit)...then it is traditional enough. The ONLY reason I would personally say not to do it, would be for safety reasons. Other than that, sounds pretty bitchin.
  20. gasserjohn
    gasserjohn
    tradtional?...tradtional is makeing your hot rod lighter/using best available engine in 67/using latest imfo available /being willing to xperment/take chances/use all your $$$togo faster....tuned jets on out side weiand intake[10,000parts]install Orings in surplus solinoids/then hide it inside the weiand tunnel...used 4th gear hydraulic port on b/m hydrostick to bypass one set points to retard timing hi gear[later it also shut off power to nitrous system too]........it was backintheday tradtional for>>> me <<< >>>IF THE FRAME TWISTS STEER IT WITH THE NITROUS BUTTON!!!!!!!!!!<<<
  21. gasserjohn
    gasserjohn
    using 3 barrel......try pics 2nd try
  22. sixfink
    sixfink
    from Germany
    God gave us nitrous to test our abilities and creativity in conceiling the lines and hiding the bottle well. Period.
  23. gasserjohn
    gasserjohn
    i want to know when it stopped being tradtional trying to go faster ...now most are afraid to ruin a hi $$$car that they paid or bought from someone else???
  24. budd
    budd
    i have a brand new Marvin Miller setup, never installed, the tank is still full from when it was bought,
  25. Great quote Little Wing
  26. Big Block Bill
    Big Block Bill
    Nitrous Oxide was indeed used for hi altitude flying. The higher you go, the less oxygen there is, so it was adapted to fighters flying support for high flying bombers, it added both oxygen and you used a richer fuel mix to make it work.I'm sure savy, real savy racers played with nitrous in the early years and probably blew up lots of stuff too. It is a pretty exact science........the nitrous masters of today I'm sure paid their dues with piles of blown up stuff.
  27. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    I guess.......... not too many HotRodders here ?.....and fewer Speed-Demons.......I still will beat my own drum no matter what anyone says and or writes......I look at it this way..I do and try things today that the true HotRodder before me would have loved to try..There was Hotrodding w/ what was available then..and there's HotRodding w/ what is available today and from prior, which makes us lucky in these times...but is the principle any different? I'd say no, but you have the people that will beat their chest that they can drive further than anyone else..and really who cares?...Do you think they thought like that in the 40's-50's or 60's..I do not think they did..that's all crap that's made up today....Their's plenty of room for all the StreetRods in HotRod clothing along w/ everything else.....some people spend way too much time challenging the past rather than building in the day...and that day is today.......Littleman....I hope to be hitting that button until I cannot push it no more in my old age.....Sure the Past is Great, but......Make your own History!!!!
    And just to make sure..I am not knocking anyone like Flamedabone, he has a bad ride ! and other's.........
    I missed this thread the first time around..
  28. Retro Jim
    Retro Jim
    Yes nitrous has been around for a long time ! It's just a very cheap way to get more HP out of your engine instead of doing the traditional way of hopping up your engine with a bigger bore , mean cam and multi-carbs on top of your mill ! A nice huffer was great too !
    BUT don't come to the HAMB drags with that shit ! :mad:
  29. Not traditional in the least. We had nothing back then that was even close to NOS.
