Could this be done? 36/40
Discussion in 'The Hokey Ass Message Board' started by sawzall, Oct 25, 2009.
  1. sawzall
    sawzall
    so I am on ebay last night.. and saw this cool mike Williams built 36/ 40 ford convert
    the cowl and front clip is 36 ford.. the rear of the car is 40 ford..
    so It got me thinking..
    say I had a 36 car cowl.. how likely would it be that I could graft a 40 ford "upper cowl" to the bottom of a 36 cowl hence resulting in a 36 ford car with a split windshield??
  2. I guess anything is possible. This is a friends 35 ford 2-door sedan.
  3. sawzall
    sawzall
    I am thinking graft one of these.. to the top of a standard 36 cowl..
  4. Tsquared
    Tsquared
    from Pratt, Ks.
    I don`t know why you couldn`t ...If the `36 hood didn`t fit the upper flat area of the cowl top. you could split the cowl top or modify the hood to fit...It`s just metal...and you`ve got a welder...
    Tom
  5. thunderbirdesq
    thunderbirdesq
    If anyone could do it successfully, I'd think it would be you. Sounds like a great idea to me, Jeff. Slice 'n Dice!
  6. mazdaslam
    mazdaslam
    Anything is possible with BONDO!!!:eek: DO IT !!
  7. sawzall
    sawzall
    thats kinda what I am thinking.. as I have a ROUGH 40 woodie cowl top thats too rough to sell.. but good enough for me..
    this silly idea came to me as I reviewed all the JUNK.. er quality parts, I have around.. the upper cowl is a good fit, because I have a spare and because I have an extra 40 woodie header to fit it..
    I think that this would make the purists scratch their heads.. and would combine the best of many worlds.. IE. the split windscreen of a 40, and the front clip of the 36..
    I was mostly worried that the 36 cowl was signifigantly narrower than the 40..
    perhaps it is NOT?
  8. Harrison
    Harrison
    I don't know about the width issue, but if it is a problem why not just graft the windshield/header area itself?
    You'll make that work a lot faster & cheaper than you'll find a '36 woodie cowl.
    Chop, chop.
    JH
  9. gas pumper
    gas pumper
    as long as the profile is close, narrowing the side to side width would be very simple.
    Gl*** size don't matter, get new cut to size of new opening.
  10. Pinstriper40
    Pinstriper40
    If you do it Jeff you gotta have a build thread on it... it's only metal!
  11. fab32
    fab32
    Roadstar here on the HAMB built a '40 coupe with a convertible/cabrolet front windshield giving him a split windshield a few years ago. There were quite a few pictures on here when he finished it. If they don't come up maybe you could Pm him and ask what exactly he did.
    Frank
  12. Rikster
    Rikster
    Roadster built in the 40's...
    Still around today... (think its the same car)
    I know... no V-Windshield but rather a chopped 36 Ford one... but it shows the combination of 36 back and 40 Front.
    Also not what you are looking for but this is a 37 Ford body with a 1940 Ford front end grafted on...
  13. Tsquared
    Tsquared
    from Pratt, Ks.
    I think the width is real close to being the same..The holes in the frame where the cowl bolts down are in the same place as the `40...The frames are the same width from `35 through `40.
    Tom
  14. The37Kid
    The37Kid
    check out the thread on the '36 3Window that was on eBay. it had a '40 upper cowl grafted to it, but not well done IMO.
  15. koolkemp
    koolkemp
    Any chance you have some pics of the body conversion in progress?
  16. chopper99
    chopper99
    I put a narrowed and chopped 49 Ford windshield frame on my 36, since I wanted a V'ed two piece windshield. I cut the 36 cowl behind the hood opening lip so the hood would still fit. The width doesn't matter, I narrowed the 49 windshield frame about 11 in.
  17. chopper99
    chopper99
    Here's a couple pics of my 36 with the 49 Ford windshield installed-not finished yet.
