Projects Couldnt help myself made a mess
Discussion in 'The Hokey Ass Message Board' started by hoodprop, Dec 31, 2013.
  1. woodbutcher
    woodbutcher
    :p Dear God.You guys keep this up and the"Big Boss"(Ryan)might have to change the name of our house to"Comedy Central".To all:May you have a healthy,happy and prosperous New Year.
    Good luck.Have fun.Be safe.
    Leo
  2. iwanaflattie
    iwanaflattie
    T't boy sure sounds like an mouthful o' marbles,aint he?
  3. Hoodprop , whun I re-wyred mye '53 F100 I moowunted the neuw fewse box insyde thuh fyrewall to the laft of the steering column . I put a 1" holewsaw through thuh inside kickpanel and ran most of mye harniss out through that . Wires for headlights etc are strapped to the underside of thuh front fender bolts and thuh rear part of thuh harniss ( Tails, stops fuel sender , elec fuel pump etc all drop down and run along the frame rail .
    Because I'm running a Lincoln Y-block the Distributor/coil etc is at the rear of the engine so I only had to run a couple wires through the fire wall .
    hope this helps .
    Posted in a reeaaall funny accent ( Kiwi ) .
