Technical Counting a spline???
Discussion in 'The Hokey Ass Message Board' started by miller, Apr 5, 2024.
  1. miller
    miller
    from New Jersey
    Hi, I need some help! I count the raised part of the spline from a th 400 trans, yoke and I count 31 plus a space. And I counted that at least 4 times. I was told it should be 32 raised areas and a space. What is what??? Thanks for any help Miller.
    Sharpone likes this.
  2. squirrel
    who told you that?
  3. Kevin Ardinger
    Kevin Ardinger
    It sounds like your yoke has a blind spline. Meaning, missing one for some other application for alignment. Pretty sure they are 32.
  4. miller
    miller
    from New Jersey
    speedway shows it as 32 plus a space.
  5. Make a centered, straight-on photo and we'll all count how many points.
  6. miller
    miller
    from New Jersey
    as suggested IMG_7098.JPG see attached pics
    Sharpone and Desoto291Hemi like this.
  7. squirrel
    that's a 32 spline yoke for a TH400
  8. Looks like 32 to me .
    Wouldn’t number 32 fit into the blank spot .
    Tommy
    427 sleeper and Sharpone like this.
  9. squirrel
    count the grooves where the splines on the shaft go....and ***ume the splines are all the same and evenly spaced....
  10. Doublepumper
    Doublepumper
    from WA-OR, USA
    Isn't it supposed to have an end cap...? I thought the empty spline was to vent the lube, for rear axle travel...?
  11. squirrel
    lots of trucks had bolt on yokes, no end cap
    but if you're using it as a slip yoke, it might be a tad short, and could leak profusely
  12. Kevin Ardinger
    Kevin Ardinger
    I counted 47
    Doublepumper likes this.
  13. miller
    miller
    from New Jersey
    thanks for the replies and yes it was from a truck or mobile home, and it does have a washer and bolt.
  14. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Just sayin',,, reason for no slip, is 2 piece shaft the slip is at the middle support.
  15. DDDenny
    I was told there would be no math today!
