Coupe Gets Boost
Discussion in 'The Hokey Ass Message Board' started by 100mph WHEELSPINNER, Feb 12, 2007.
  1. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    Here are some pics of the low bucks supercharger that I just put on my coupe. It is going to fit under the hood but I may do a side scoupe for some cold air...:) :) :) It is a bd-11 on a 383. with a 4-speed. fun fun fun. see ya on the streets.
  2. Plowboy
    Plowboy
    Where's the pic homeboy?
    I was wondering if you were still alive. Ha Ha Ha
  3. joeks
    joeks
    cant see the pics.
  4. usedall9
    usedall9
  5. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    sorry heres the pics
  6. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    more
  7. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    I started my own buisness havent had time to post
  8. the-rodster
    the-rodster
    Sweet!
    How low buck?
    Rich
  9. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    $500 head unit (used)
    $100 pulleys
    hat $188 new (could be cheaper)
    Fuel pump $115 New (I converted to a boost sensitive aka drilled and installed a fitting)
    carb upgrades....(floates $24 and some epoxy)
    exhaust pipe for intake $20
    Brackets (i designed and cut out of s****)
    Reverse flow water pump New $35..............................
    The look on the kids face in a new mustang...... priceless
  10. t-town-track-t
    t-town-track-t
    from Tulsa
    Thats killer man, but there has to be something you can do about the ricer boy air cleaner!
  11. Tudor
    Tudor
    from GA
    how many lbs and what's your compresion ratio?
    looks cool - good job.
  12. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    The air cleaner is temperary. I need a small round air cleaner like they run on 2 4's. I did the install in a weekend with a few friends. The car will have a full hood with just the headers sticking out when im done.
  13. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    Its around 9:1 383ci. Junk heads and 6psi. I am going to work the bugs out and turn the boost up to around 9psi. The only time that I will turn the timing up is with race gas or e85.
  14. jonski und29
    jonski und29
    Hell Yeah! Now you can blow another rear end out!
    Seriously, that looks really good.
  15. brandon
    brandon
    was going to ask what type of pump you were using.....i bought a used procharger before christmas.....had talked about sticking it on my model a ....bought a late model malibu to stick the motor in ...but sold it last week....so i am back to a model a install....what are you doing about timing and such .....? brandon
  16. 2manybillz
    2manybillz
    I really like the car and the blower idea but the mixed genres kinda make me itchy. It'll definitly look better with a hood covering it. Think about making the brackets, belts and pipeworks fit in with the period look of the car - then you could leave the hood off. Not trying to be negative, my opinion, your car.
  17. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    I am using a carter pro series mechanical pump that I got from jegs. If you need pics of the alteration then I can show you. all you do is drill out the vent on top of the pump and press a piece of brake tubing into it. Then you run a rubber line up to a fitting in your hat so that the boost pushes on the diaframe of the pump giving you one more pound of fuel pressure for every pound of boost. this can be done with any pump but it needs to have a high gph (at least 120) Mine is 172. I have the timing turned down quite a bit for safty at first. its at 8 intial and 28 total.:D
  18. HemiRambler
    HemiRambler
    Low buck, innovative, functional......
    ALL the ingrediants for a true Hot Rod. Nice Job!
  19. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    For now its in the form follows function faze. The car used to have fourbar and I finaly got around to it. I am going to make it fast then I will make it look good. But not if it gives up alot of perfomance. after all I have a hood.:)
  20. ray
    ray
    from colorado
    how does it GO? :D
    haha.
    now get rid of that exhaust pipe intake pipe! and that tight 180 bend. i see you're running the Extreme Velocity carb hat, yeah they're a few bucks more, but there's power in there. i bought one, then sold my old procharger hat for almost what i paid for the EV unit.:D
  21. yngrodder
    yngrodder
    Looks good, You missed a good time at the pile up!!!!! You will have to go with us this year.
  22. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    sounds like a great time...... I'll go this year....do ya still have the coupe.?
