Coupe Progress pics!!!!!!!!! TECH???
Discussion in 'The Hokey Ass Message Board' started by jonnycola, Apr 20, 2004.
  1. jonnycola
    jonnycola
    Wow, I can finally get on the Hamb again. I've been having that stupid thing where I sign in, and it immediatly signs me off again.... but now that I've got that figured out, I can throw some pictures on here to show I'm actually getting the car done.
    Ok. so the last time it was on here, Bob and I had just finished up the frame, and the motor and Body were just sitting on there.
    Here's how it was when I got it...
    <img src=http://img34.photobucket.com/albums/v103/jonnycola/1931_Project_Model_A_Left_side_whole.jpg>
    when last seen......
    <img src=http://img34.photobucket.com/albums/v103/jonnycola/MVC-196S.jpg>
    and now....
    <img src=http://img34.photobucket.com/albums/v103/jonnycola/MVC-218S.jpg>
    Since then, I tore into the motor, an looked over it to see that it would work. the cylinder walls looked great, and I could see that it had been rebuilt before. So that and Crestliner's telling me that it was running a few years ago, makes me think that it should work out well.
    <img src=http://img34.photobucket.com/albums/v103/jonnycola/MVC-203S.jpg>
    Once I got that done, I did the same thing to the transmission (which I got from Jaker and I believe is out of a 62 or 63 Fairlane, but I'm not sure) and it looked pretty good. So I painted them both, as well as the bellhousing (which I got from Tuck... who delivered it all the way from canada!), in a high temp black and bolted them together. I also installed my new head studs, and put my intake manifold on.
    <img src=http://img34.photobucket.com/albums/v103/jonnycola/MVC-217S.jpg>
    Then, I got it bolted in the frame..... which I also painted, as well as the front end and rear end parts.
    <img src=http://img34.photobucket.com/albums/v103/jonnycola/MVC-220S.jpg>
    So next, I got my rear brakes all apart and cleaned (still have to get them on) and I put the open drive conversion on the rear end. Getting the sleave that olds the old driveshaft to the rear end turned out to be the hardest part.
    <img src=http://img34.photobucket.com/albums/v103/jonnycola/MVC-229S.jpg>
    Then the body went back on... and it was time for the floor and pedals.
    I got a 40 ford pedal ***embely with the car, and Bleed said that I should use a Mustang double chaimber master cylinder, because it's the safer alternative.. so I had to figure out a way to make the two mate together. So I came up with this idea that mounts them off of the transmission crossmember... The small box is made out of 1/4" plate, and it's a 4x4 square. I drilled and tapped the holes, and then modified the rod so that it can be bolted to my pedals.
    <img src=http://img34.photobucket.com/albums/v103/jonnycola/MVC-234S.jpg>
    I threaded a piece of hexagon stock, and ran a die over the end of the rod, and lock***ed it on there. So now it's nice and adjustable, and it should work out ok. I also made up my lutch linkage, but I made it too weak, and it will most likely fold over when I push down the clutch (no clutch in it yet)... so it's going to have to be made over... but it's all a part of the learning process.
    Next came the floor.
    I decided to use some 3/4" square tubing, because that's what Bleed used on the Roadster pickup, and even though it might be overkill, I'd rather have it stronger than it needs to be. So bob explained on how I should lay out my grid, and where it should tie into the body, and I went home and started on it.
    <img src=http://img34.photobucket.com/albums/v103/jonnycola/MVC-250S.jpg>
    First I got the frame up on jackstands, and shimmed them so that the whole thing sat perfectly level. Then I got the body centered on the frame, and used one of the original body mounts as a temp mount, and welded it to the frame. Then I started on the grid. It ties into both door jams, the front of the cowl, the front part of the wheel wells in the back, and then I put in back supports as well. I still have a couple pieces to add in, but this is how it is right now.
    <img src=http://img34.photobucket.com/albums/v103/jonnycola/MVC-270S.jpg>
    <img src=http://img34.photobucket.com/albums/v103/jonnycola/MVC-272S.jpg>
    <img src=http://img34.photobucket.com/albums/v103/jonnycola/MVC-273S.jpg>
    <img src=http://img34.photobucket.com/albums/v103/jonnycola/MVC-275S.jpg>
    Oh yeah, I also made up a big tall shifter out of some stainless hexagon stock, and got my firewall in.
    <img src=http://img34.photobucket.com/albums/v103/jonnycola/MVC-257S.jpg>
    I also started on my gas tank. I bought an 11 gallon compressed air tank at home depot for 25 bucks, pulled the air fittings off, welded a piece of 2" plumbing pipe where the regulator sat, and then turned a cast plumbing cap on the lathe to clean it up a bit.
    <img src=http://img34.photobucket.com/albums/v103/jonnycola/MVC-295S.jpg>
    I've gotten some other little **** done.... re-lined and rivited my brake shoes, got the generator rebuilt and cleaned up, got the distrubutor repaired and cleaned with new points and a condenser, bought a fuel pump and started monkeying around with that and a few other things I cant think of.
    So thats where I'm at now. I hope it's not too many pictures, and I hope photobucket dosen't kick me off their site for too much traffic but yeah. It's actually getting done. So far the hardest part of this whole thing has been keeping my life's priorities straight. It's easy to get wrapped up into this stuff... and working on your hot rod is way more appealing than going inside and doing algebra homework... but I think i've got all that **** figured out, and now I can do both.
    So Bleed and I are going to do the steering in the next couple weeks, I've got my brakes to finish, skin the floors, get my radiator mounted, make the driveshaft, get the motor finished, wire it, run my gas lines, and a few other little things, and it's drivable.
    But I figured... I should post when I have something constructive to contribute, and I finally have something.
    So there ya go.
    jonnycola
    kidcampbell71 likes this.
  2. Unkl Ian
    Unkl Ian
    Bob Bleed is a bad influence. [​IMG]
    Looks excellent 'Cola.
  3. Killer
    Killer
    looks really good.
  4. Whew! Hell of a post. The car really is coming along great. I really like how ya made it a Tech post too. It will help me some day.
    Thanks for sharing,
    Joel [​IMG]
  5. plan9
    plan9
    righteous man...
    excellant post
  6. lucky_1974
    lucky_1974
    Great Job... looks real good. Keep us posted.
  7. disastron13
    disastron13
    nice shop couch, man
  8. jonnycola
    jonnycola
    [ QUOTE ]
    [/ QUOTE ]
    It's ***tacular... and it matches my van.
  9. bobbleed
    bobbleed
    from Awesome
    I've been trying real hard to be a positive influence on this kid......... It's a lot harder than I thought.
    Did you get your homework done, you little *****?
    Isn't it past your bed time?
    When are gonna learn to not be such a ***?
    See, I'm a good guy.
    I keep trying to tell him that he should be out putting his hands up some teenage girl's shirt, while he still can.....
    But he keeps working on that damn Coupe.
    He's a smart little mother****er, but he's still got a lot to learn.
    Looks good kid, now maybe you'll get to third base.HaHaHa
  10. bobbleed
    bobbleed
    from Awesome
    By the way, you were suppose to use the air fitting inlet as the outlet for the tank, and make a new hole for the filler........ Looks good anyway.
    AND that's MR Bleed to you. HaHa
  11. You better get to bed because you have "Skool" tomorrow...! [​IMG]
    I think I'll give you an "A" on this post...! [​IMG]
    Mark
  12. Make sure you vent that tank. Dean
  13. topdeadcenter
    topdeadcenter
    Another Wisconsin RULER! That looks bad-***!
    Mike
  14. I'm thinking you just inspired a bunch of us old farts to get off our cans and get out to the shop.
    Nice work!
  15. Kevin Lee
    Kevin Lee
    Super Moderator
  16. Donzie
    Donzie
    There's a world of difference between those first 2 photos.
    The car looks great. Nice work.
  17. burndup
    burndup
    from Norco, CA
    DAMN YOU, PUNK*** KID!!! Not only do you have a *****in kar, you have Bob Bleed for a Kung-Fu master...
    YOU ****!!!
    I'm not JEALOUS, or anything! [​IMG]
    Right on man, you've lucked out bigtime, and you're doing some really good work. Dont do any stupid **** like crash it or something once its on the road... Dont let your "buddies" borrow it...
    -J
  18. Kerry
    Kerry
    Lookin sharp!
  19. Looking good kid, now where's my MONEY????HAha! Give Bob 100 skins for my radiator, I need to get tha H-bomb rolling.
  20. cleatus
    cleatus
    from Sacramento
    [ QUOTE ]
    I keep trying to tell him that he should be out putting his hands up some teenage girl's shirt, while he still can.....But he keeps working on that damn Coupe.
    [/ QUOTE ]
    He's just patient 'cause he knows when he shows up in that 5-window, they'll be ready for more than a ****** fluff.
  21. fab32
    fab32
    Whew!!! Looks like you have made some serious progreess on that A. It's going to be a sweet looking ride when it's done and people are going to wonder how someone so young knows so much about how to do an OLD TIME looking hot rod.
    Frank
  22. Petejoe
    Petejoe
    from Zoar, Ohio
    Thats one bad looking coupe! Good work.
    Let me brighten it up a little.
  23. jonnycola
    jonnycola
    [ QUOTE ]
    [/ QUOTE ]
    It's no big deal, Lieutenant Commander Bleed... Max Wedge and Berger are still putting their hands up 15 year old girl's shirts... so I figure I can get away with it until I'm at least 25.
    Yeah.... it's really coming along. This hot rod stuff is a *****. I totally thought it was going to be alot easier than it has been.... but I've never done something so rewarding. I imagine the sence of acomplishment will be incedible once it's finished..... but I've still got a ways to go.
    Maybe I'll take this oppertunity to pick your guys' brains... is the oilpan that I have a normal truck pan, or has it been modified to have the large oilplug? I'm not good at this flathead stuff....
    I'd rather have a 365 Caddy in it
  24. Bob K
    Bob K
    from Antigo Wi.
    Great Post Man.
    What's with the midget style go cart on the shelf???
    B [​IMG] B
  25. 30roadster
    30roadster
    I know this probably means i'm doing it wrong...but that post was better than ***!
    AWSOME PIC'S!!!!!!!!!!
  26. 34Fordtk
    34Fordtk
    That pan is a truck,it has the big clean out in it.
  27. subrock
    subrock
    nice gs sitting back there. you could sell that and fund a whole nuther rod.
    Ian
  28. BELLM
    BELLM
    Hot damn thats a good looking car! Thanks for sharing.
  29. Putting yer hands up young girls shirts IS A FUKIN' ART DUDE!! Its hard work being ROCKSTARS, so get with it!!
