Projects Couple of questions on a 40 banjo under 32 rails
Discussion in 'Traditional Hot Rods' started by NB141FD, Dec 4, 2020.
  1. NB141FD
    NB141FD
    I'm planning on using a complete 1940 rear end assembly under my 30 coupe running an 8BA and 39 transmission. For those of you who have gone this route before, I have a couple of questions. First, how many of the 10 leaves did you remove for a good ride? Second, did you reverse-eye the main leaf? I'll be using a 32 frame from Blackboard Hot Rods with a flat rear cross member.
  2. NB141FD
    NB141FD
  3. Aaron D.
    Aaron D.
    I used the top tapered leaf and four of the long leaves. I also reversed the eye of the main leaf. The short cut off leaves are used as spacers. After driving it for a year, the ride is good but just maybe a little soft.
    You should maybe keep one more leaf than I did.
    stillrunners likes this.
  4. trevorsworth
    trevorsworth
    Did you convert your 40 axle to spring over? Do you have any more detailed pictures? I am about to be doing that.
  5. NB141FD
    NB141FD
    Aaron, thanks for the info. I'm using the 40 spring pack on a deuce rail setup. It's helpful to see the your spring setup. I hadn't thought about needing spacer leaves. I'll plan on leaving at least 6 leaves.
    Trevorsworth, I don't know if your question was for me or Aaron. I'm keeping the stock 40 behind the axle spring pack on a flat rear crossmember. I was trying to find out how many leaves to remove for a good ride and whether I should reverse eye the main leaf. Tony
  6. trevorsworth
    trevorsworth
    It was kind of for both of you, I didn't phrase it very well lol.
  7. alchemy
    alchemy
    Only you can say if the main leaf should be reversed because nobody knows the height of your crossmember. We would just be guessing.
    As for removing leaves, I'd think that a light A high boy would need maybe half the leaves of a fully loaded stock 40. Keep the main, remove the next, keep the next, remove the next, and so on. Keep the stock top leaf with the tapered edges. Don't throw any away in case you need to add some back in.
  8. NB141FD
    NB141FD
    Thanks Alchemy, I think I'll get a reversed eye main leaf; one of the eyes on my current main leaf is rusted through and I need to replace it. I appreciate the advice on the leaves, it makes sense to start out with half the leaves and go from there.
    Tony
  9. I usually start with 7 leaves and go from there. I am not sure where I came up with that number. LOL
  10. NB141FD
    NB141FD
    Thanks porknbeaner.
  11. Aaron D.
    Aaron D.
    You can get an idea of what I did starting at 8:00.
    Hotrodmyk and trevorsworth like this.
  12. NB141FD
    NB141FD
    Thanks Aaron, and thank you for your videos, I've been following them for the last couple of years and find them very helpful.
    Tony
    Aaron D. likes this.
  13. Frames
    Frames
    kinda hard to install the spring if the it has reversed eyes.
