Technical Cowl lights
Discussion in 'Traditional Hot Rods' started by simon sinkinson, Sep 3, 2019.
  1. simon sinkinson
    simon sinkinson
    thanks all
    all great advice
  2. Blues4U
    Blues4U
    from So Cal
    Well this has turned out to be an interesting thread. I didn't pay it much attention to start with because cowl lights just don't seem like much of a hot rod item to me. I guess some previous owner opened these bolt holes up for some reason, and I just ***umed that is where the cowl lights mount. Apparently not.
    So I'm still confused how they install, there are no holes for the lights where you guys are showing them mounted.
  3. flatford39
    flatford39
    You are missing in a screw in your hole. You need to drill your own holes in the cowl panel for cowl lights. Your car never had them installed. This is in response to Blues4U
  4. scrap metal 48
    scrap metal 48
    If your headlights are low enough you can mount them upside down by putting on opposite sides... ** clic pic** 100_3565.JPG
  5. HOTRODPRIMER
    HOTRODPRIMER
    How does a dog like you get a babe like that? :D HRP
    RRanchero Rick and chryslerfan55 like this.
  6. sloppy jalopies
    sloppy jalopies
    Haven't seen it,
    but how about using them as parking / blinker light mounted on the frame near the head lights...
    any pix ?
  7. simon sinkinson
    simon sinkinson
    woof woof
  8. Hotrodmyk
    Hotrodmyk
    There is a support brace inside the cowl that has about a 3/8" hole in it. This can be used to locate the hole for the larger outside hole. A wood block goes in between this brace and the outside panel to prevent crushing as mentioned in an earlier thread. The cowl light bolts inside using the small hole.
    Mr48chev and Blues4U like this.
  9. Simon, To order those from U.S.A. you will get hit an extra $35 import tax plus the $35 postage which also seems a little on the high side. Surely you can find something local. Forget about buying a cowlband from the U.S.A. that will be bent and twisted by the time it reaches you.
    scrap metal 48 likes this.
  10. simon sinkinson
    simon sinkinson
    It it the huge Beaulieu Auto Jumble this weekend ( just up the road ) I will try and find something there first .
    Thanks for the advice
  11. The37Kid
    The37Kid
    If you find a cowl band be sure it has the steel threaded studs on the bottom, good ones are getting harder to find and they fit better than the reproductions. Bob
