Hot Rods Cowl steering using Mopar box question
Discussion in 'The Hokey Ass Message Board' started by bantam, May 31, 2014.
  1. bantam
    bantam
    Hi guys -
    I am putting together a cowl steering set-up using a Mopar box AND using the stock Mopar pitman arm as shown in the photos. Question - given the taper on the tie rod end of the stock Mopar pitman arm, what can I used to connect the pitman arm to the draglink?
    I presume I can't use a heim joint since heims are not designed to work with a tapered tie rod instead being designed for a bolt.
  2. bantam
    bantam
    A couple more pictures. One of cowl and one of steering arm at spindle the drag link will connect to.
  3. Airhart
    Airhart
    Cut the tierod end off, drill a hole in new end of pitman arm, attach hiemjoint.
