Cowl vent in a Model A
Discussion in 'The Hokey Ass Message Board' started by Toqwik, Jul 31, 2009.
  1. Toqwik
    Toqwik
    Would like to put a cowl vent in my model A (31) anyone know of a good donor?
  2. Jkustom
    Jkustom
  3. EVANS and 3 97s
    EVANS and 3 97s
    Brookville sells all it takes.You must change tank location of course. It will make your car much more comfortable ,good luck.
  4. Toqwik
    Toqwik
    The tank was gutted in the 50's so that is no problem. I'm just not a order and get guy, rather fit something in from a era-type car.
  5. Stock filler with a cap with one louver. Keep a solid cap for wet times and screw on the louvered one when hot..................you did keep the opening window? Henry had an amazing vent system in A's that was discussed last week.
  6. Hackerbilt
    Hackerbilt
    Hmmmm...cool!
    Or maybe adapt a small carb scoop to screw-on in place of the cap!
    (Would look either really cool or totally stupid! :D)
    Inside, a dual tube duct setup could be made to direct the airflow onto you and your p***engers feet or wherever.
  7. Clark
    Clark
    32 chevy works.
    Clark
  8. Stovebolt
    Stovebolt
    What about Early 60's Studebaker guard vents mounted in the cowl side panels????
  9. Chris Stapley
    Chris Stapley
    26-27 model T is a nice clean little vent too!
  10. Jkustom
    Jkustom
    True true! My 34's vent is leaded in, done who knows when.. It's still in there though, just closed :)
  11. lakeroadster
    lakeroadster
    from *
    With Henry's stock "ventilator" I am surprised you need a cowl vent? On my '30 Model A Sedan if I open the front window about an inch the air flows quite well behind the '67 Camaro dash.
    Here are some pictures of the fuel door on my '27 Model T.
    A cl***ic case of using what I had laying around I modified John Deere 265 throttle lever ***embly to make an actuator, and now use the gas filler as a cowl vent.
    Clean, simple and works.
  12. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I would think that the ablity to open the windshield would be more than enough
  13. sko_ford
    sko_ford
    a 47 53 chevy truck would be a cheep alternative
  14. doctorZ
    doctorZ
    i put a '32 vent on my '30 sedan. i just like the way it looks! what about using the cowl from a dodge? you could use the dual vents!!
  15. Toqwik
    Toqwik
    Duual vents, I like that idea........... That Camaro dash looks nice in that sedan !!!!
  16. Mr48chev
    Well, I was going to throw in a vote for the Brookville patch and cowl vent http://www.amazon.com/1932-FORD-COM...0?ie=UTF8&s=automotive&qid=1249176239&sr=1-13
    But that is way too spendy for my budget and I wouldn't feel comfortable telling someone else to use it unless they had deep pocket or that was the only thing they thought would fill the bill. I'd leave that to the guys who needed to save a ******ed up Deuce Cowl and look for a good doner.
    Check the Semi truck cabs from a few years back out as I think a lot of them had opening vents like that. The Ford pickup unit would probably be the easiest to find though.
    <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
  17. lakeroadster
    lakeroadster
    from *
    Thanks. But who would have ever thought that would work? :D
    At the risk of catching some wrath.... Sometimes thinking past the "traditional" stereotype will yield something "new". Go figure.
  18. cheezwiz
    cheezwiz
    ....all BROOKVILLE '32 stuff, easy !
  19. Granted, you get some airflow from an opening windshield, but the cowl vent dumps air onto your feet.
    Take note too, if you're not running weatherstripping - commonly done in roadsters - hot air enters the vertical door gaps so the cowl vent helps there.
  20. doctorZ
    doctorZ
    i demand more pics of this car! please?
  21. millersgarage
    millersgarage
    A carb scoop in place of the gas cap works well, and cheap.
    of course, you still need the gas filler neck on the tank........
  22. millersgarage
    millersgarage
    I believe I checked out the A in question at GoodGuys Indy. Nice car
    here is a shot I took
  23. sloppy jalopies
    sloppy jalopies
    I found a boat vent scoop, it has a thick alum. base that screws up into the scoop... the 3" ish hole in it slides on over the A gascap... an added screen, a threaded tube welded to a new steel base and a long allen set screw ... ebay for about $35.00. ... scoop fits with or without the gascap...
  24. BJR
    BJR
    Put a carb scoop on the gas filler neck.
