Technical crab cap condenser question
Discussion in 'The Hokey Ass Message Board' started by nutter_street_rodder, Jun 14, 2024.
  1. nutter_street_rodder
    from Nevis MN
    A few years ago I bought a "new" condenser from a parts supplier. Today I happened to notice then sealed plastic bag it is in has an oily, almost honey substance in it. I checked it with my multi-meter and it checked good. Then to try it even more I installed it on the car. Seems to be working fine. Is this a time bomb that going to stop working soon?
  2. alchemy
    alchemy
    So, does it taste like oil, or honey?
    The bad rep that new condensers get nowadays would make me keep every old one that still tests good. Maybe throw an extra in the toolbox though. You do have a toolbox in the car, right?
    alanp561 likes this.
  3. Doublepumper
    Doublepumper
    from OR-WA, USA
    Many condensers are made (rolled), using a wax paper type material for insulating the foil conductor sheet (that enables them to work), inside them. The wax is used to help prevent moisture from oxidizing the foil. Possibly some wax is leaching from that. If that's the case, it shouldn't compromise the condenser in any way, that I can think of.
  4. '29 Gizmo
    '29 Gizmo
    from UK
    Capacitor technology has evolved significantly in recent years. Older designs deteriorated with age, modern ones are not so prone.
    Buy a new one.
    Tow Truck Tom likes this.
  5. distributorguy
    distributorguy
    from MN
    Yes, the old paper layer will break down and capacitance values will drift from .2 mFd up to .3, .4...
    Newer poly/foil capacitors don't degrade as quickly, but can have the same temperature related failures.
  6. alchemy
    alchemy
    Can you guys give us a brand and part number of a “modern” condenser for a 12 volt old Ford distributor? A good one with a proven track record?
    Beanscoot and Desoto291Hemi like this.
  7. Budget36
    Budget36
    I don’t think they are voltage dependent. I switched my 221 to 12v and used an NOS condenser.
  8. alchemy
    alchemy
    Those guys say there’s a new type of condenser we should be using instead of the old dried out ones. Just hoping they can give us a good answer.
    Desoto291Hemi likes this.
  9. Budget36
    Budget36
    I get ya. Maybe you can see if @tubman condenser is adaptable?
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    I have never had a failure on a 70's - 80's NOS condenser, I test them on my dist machine (zero failures) and use em....
  11. distributorguy
    distributorguy
    from MN
    I believe all the new stuff from Napa is poly-film. We've been adapting automotive rated circuit board capacitors and adapting them to fit in various applications where few options are available.
    I see 70's and 80's condensers (NOS and used) failing all the time, but I'm still rebuilding 20-30+ distributors a week. Older NOS options are pretty much all DOA now. If they still work, they'll fry your points at .3 - .4 mFd ratings and climbing.
    BTW, I don't trust the old Sun capacitor testers any more than I trust their dwell meters. At least you can verify the dwell meter by counting degrees on the degree wheel. All 3 504's I have don't have accurate capacitance gauges.
    BTW, Mark I bought your spare machine years ago and still use it (in rotation) to this day!
  12. Doublepumper
    Doublepumper
    from OR-WA, USA
    Budget36 likes this.
  13. I’m game for this adventure !
    20-30 distributors a week are a lot of units,,,,you must have a good supplier for the condensers ?
    That’s about what,,,,,,4 or 5 a day,,,that’s some quick turnaround ?
    Please let us know your source !
    Tommy
  14. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    The condensers we have to buy nowadays are mostly imports and often bad right out of the box. Aside from that, condenser mounting is flexible. You can attach it to the dist. side of the coil, if need be. Just try to keep the wire as short as you can. You have many options.
  15. Beanscoot
    Beanscoot
    Still waiting for that part number....
