Hot Rods Crab on a 51?
Discussion in 'The Hokey Ass Message Board' started by 61Tudor, Feb 19, 2017.
  1. 61Tudor
    61Tudor
    Is it possible to put a crab dizzy on a 51? I have the crab dizzy and timing cover. Need a mechanical advance unit for my twin 97 set up and I have these parts.
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    Yes, but you will have to change out the cam.
    Easiest solution would be to install one of GMCbubba's units, a converted gm distributor or change to an electronic unit like MSD.
    tierod likes this.
  3. 61Tudor
    61Tudor
    Yes, I know that would be the easiest. I am s ****er for punishment!
  4. tubman
    tubman
    There was a thread on the "Ford Barn" about this recently. I think they showed a way to do it without changing the cam by cutting the gear off the later cam and machining a slot in it. I like the serviceability of post distributors, so I just skimmed the thread. I think that was the jist of it, though.
  5. tierod
    tierod
  6. If it's done right: you will need to change the cam to early pre:49. You will also need to change the timing gear set to early pre:49. On 32-48 engines the cam thrust pushes towards the block. On 49-53 the cam thrust is towards timing cover. So you will need a early cam and timing cover plus early timing gear set.
  7. 612DOR
    612DOR
    While I have all those parts, it's more trouble than it's worth methinks.
