Cracked flathead block
Discussion in 'Traditional Hot Rods' started by coyotedustr, Dec 19, 2014.
  1. coyotedustr
    coyotedustr
    from chicago
    Let me start out by saying I understand I would prefer if my block had no cracks. But I remember reading someplace that the cracks between the water jacket and the bolt holes don't matter. I see no cracking that goes to the cylinders but I have three or four water jacket to stud hole cracks like this on my block. Is this block still worth sending out to get magnfluxed?
  2. Mike51Merc
    Mike51Merc
    You read right. Those cracks are nothing. Not even worth trying to fix. The head gasket will take care of that.
    Clay Belt, wheeldog57 and Vanness like this.
  3. carmuts
    carmuts
    If you look closely you might even find the part number for that crack. Rod
  4. coyotedustr
    coyotedustr
    from chicago
    Good news then. Looks like I may have found an Ok block on my first try. Took a gamble on a 8ba out of a 50 F1 with the trans and bell housing. Hopefully it will still check out when it gets to the engine shop
  5. 29AVEE8
    29AVEE8
    Suggest you pressure test and magnaflux before spending big dollars. As stated the crack you have shown is not a problem, very common.
    Skankin' Rat Fink likes this.
  6. coyotedustr
    coyotedustr
    from chicago
    For sure that's my next move. I'm just glad it's so far so good
  7. ronnieroadster
    ronnieroadster
    Rumor has it there was actually a guy at the Ford plant whose job it was to put those deck cracks in the blocks before they left the foundry. As everyone has said they are harmless you could go one step better and have them heli coiled doing that would eliminate any pulled threads if you use head bolts. If you decide to use studs that would be better I have found those threaded holes to be weak at times when torquing using head bolts. :eek:
  8. prpmmp
    prpmmp
    Neat loc-s***ch video!! Pete
    Hdonlybob likes this.
  9. tubman
    tubman
    I have always found that blocks from trucks and Mercury's are a better than from Ford cars. Why? better cooling from bigger radiators. I even have one from an 8RT that doesn't even have the "part number" cracks! Your block looks pretty good to me!
    Clay Belt likes this.
  10. flthd31
    flthd31
    One problem I see is the hand grinding you're doing on the deck surface. That'll get you in trouble real quick.
  11. Asphalt Demon
    Asphalt Demon
    from Australia
    Well, my case may have been a rarity but one of my engines had the exact same cracks.And i ran it. I had a $12 thermostat destroy that engine.The thermostat closed up and that crack opened up and became a high temperature water blaster,melting my head until it ate it away to the cylinder edges,and then lined the two cylinders with molten alloy. Lesson learned the hard way i don,t run thermostats now or i always drill holes in them if i do. Johnny
  12. coyotedustr
    coyotedustr
    from chicago
    Just ran a 3m pad over it, no grinding.
  13. PackardV8
    PackardV8
    I've never, ever seen a flathead Ford V8 block with miles on it which didn't have cracks.
    That one in the photo is no problem. Those which go from the valve seats to the cylinder, that's another story.
    jack vines
  14. ottoman
    ottoman
    from Wisconsin
    Even those 3M discs remove material... we used to get heads from the dealership for repairs and every head the guys cleaned up with the 3M discs needed surfacing... they remove more metal then u think!
    deathrowdave likes this.
  15. BLUDICE
    BLUDICE
    Those are so common Ford gave them a part number. To find a flathead without a crack or two would be very rare.
    verde742 likes this.
  16. 68Dodge
    68Dodge
    from Wichita
    Just remember if you mag you're block make sure they demag it good or else the residual can screw with your gauges.
  17. F-ONE
    F-ONE
    from Alabama
    I had a fellow tell me once to use Super Glue on that type of crack when ***embling the engine.
  18. verde742
    verde742
    I agree
  19. verde742
    verde742
    milk came out my nose. 'wear white at night"
  20. tig master
    tig master
    from up north
    A also common place for cracks is from the valve seat down into the port and you don't have the valves out in your pic so take a look there also.
    T
  21. weeniedawg
    weeniedawg
    The only justification for using a flathead Ford is to restore an old one to original condition. I've never seen one that didn't have cracks in the block. And when you can buy a brand new Chevy long block for $1600, why would anyone want to build one for a hot rod. If you're a die hard Ford guy, Windsor crate motors are cheaper than building a flatty. There's no way to make a flathead make more power than a small block Chevy or SB Ford.
    Matt Miller and zzford like this.
  22. K13
    K13
    Nice first post. Dig up a 4 year old thread to make disparaging comments about stuff that is the essence of this place. You are clearly on the wrong board.
  23. alchemy
    alchemy
    Get lost Wiener!
  24. christmas tree
    christmas tree
    Weeniedog If you were not there you might not understand. Its a trip down memory lane. 16804677_1710180322341677_966733510_o.jpg
    Vanness likes this.
  25. Atwater Mike
    Atwater Mike
    Those little cracks in the stud bores will actually leak under pressure. The water will creep up the head BOLTS ('49-'53 type fasteners) but if the '32-'48 studs and nuts are used, (and the studs sealed) the problem is usually solved.
    BUT, as an old flathead guru once told me (Harry, at Automotive Industrial Supplies) "After any appreciable machine work on the flathead Fords, Mercurys, and Lincolns AND Cad flatheads, prior to starting and warming up the engine, add a small can of heavy duty block sealer to the cooling system. It is good insurance."
    1980: A friend had a nice Nitro black lacquer '32 Tudor sedan he had just finished. He came to the shop, asked me to take a look. The 284" Rod Furtado-built flathead had spit out some water in droplets...out the side louvers some whitish-looking stains of water had settled, in thin streams...both sides.
    The Edelbrock heads were bubbling slightly, maybe 8-10 bolts per side...
    I knew Furtado's practices, so the engine ***embly would be thorough...no need to tear a head off, not yet, anyway.
    I drained the water coolant, added a can of block seal, removed the hood, and told him to drive it, at least 30 minutes...He did, and when he returned the bolts were no longer seeping. I had also cleaned his beautiful Rootlieb hood sides, and we set the panels back on.
    He drove the car a lot, so periodically I'd ask him how it was doing. He had added Prestone as directed (by me) and said there was no more problem.
    bowie and alanp561 like this.
  26. Atwater Mike
    Atwater Mike
    Weeniedog: Memory Lane is just 1/4 mile long.....
  27. alchemy
    alchemy
    Make sure when any of your guys are cleaning a flathead to NOT retap the stud holes. Most of our tap sets will cut those threads too loose, and then they will weep more. (Wisdom conveyed by Bruce Lancaster, wish he would come back) If you need to clean rust, cut a lengthwise groove in an old stud and run that up and down the hole a couple times.
  28. Vanness
    Vanness
    Looks ok here. I bought 6 flathead Motors this summer. All of em had cracks like you said. One didn’t ...the one with the 4” merc crank and it was a merc motor :). Thank you!!! Build it.
  29. Mike51Merc
    Mike51Merc
    There's lots of stuff cheaper than a Flathead, but nothing else makes that priceless sound.
  30. Flathead Dave
    Flathead Dave
    from So. Cal.
    I had a Wiener Dog once. Named him "Richard The Great".
    Jet96 likes this.
