cracked head repair ?
Discussion in 'The Hokey Ass Message Board' started by onekoolkat1950, Jun 15, 2012.
  1. onekoolkat1950
    onekoolkat1950
    just found out one of my navarro flat heads is cracked. if i have it welded at the machine shop should i expect the repair to last or will it just crack again in the future?will i be chasing my tail?
  2. terryble
    terryble
    from canada
    If and it is always a big IF your shop knows what they are doing you should have no problems with that head.
  3. Mr48chev
    If you have the right welder do the welding I don't see a big problem with it but you do need to to have the right person do the welding. Someone in that area of the country can probably give you the name of the go to guy around there.
