Technical Cragar Coverup
Discussion in 'The Hokey Ass Message Board' started by blowby, Aug 19, 2021.
  1. blowby
    blowby
    from Nicasio Ca
    Been thinking Cragars are a bit modern for my 1938 pickup. So I bought some cheap VW smoothie hubcaps and put them over the spokes to see. I'd have to make clips off the lug nuts to use them. Kinda like it. I could run them during the week and pop them off on the weekends when I go cruising for babes.
    dana barlow, cactus1, jnaki and 7 others like this.
  2. Jalopy Joker
    Jalopy Joker
    unique idea - likely do not not want to drill holes - but, how about using the screw that holds on stock S/S center cap to help hold down big caps? - could use a bullet type nut on face of big caps
    dana barlow and Deuces like this.
  3. seb fontana
    seb fontana
    from ct
    Looks ok I think! You pick up chicks now?
    dana barlow, loudbang and Deuces like this.
  4. hotrodA
    hotrodA
    “There’s just something women like about a Pickup Man.” (Joe Diffie)
  5. e1956v
    e1956v
    Alliance Vendor
    RIP Joe
    Deuces likes this.
  6. blowby
    blowby
    from Nicasio Ca
    I thought about acorns but didn't seem right. But yeah, some of these bullet valve caps maybe. Hmm.. Thanks!
    If one ever gives me a second look I will!
    seb fontana and Big mike 1968 like this.
  7. harpo1313
    harpo1313
    from wareham,ma
    It takes a little bit of the knarly out of it. good idea.
    blowby and Big mike 1968 like this.
  8. hotrodjack33
    hotrodjack33
    Don't look like a whole lot of room in there...better only cruise for skinny chicks;)
    Hnstray, loudbang, swade41 and 4 others like this.
  9. big duece
    big duece
    from kansas
  10. The37Kid
    The37Kid
    X2 :)
    Kan Kustom likes this.
  11. millersgarage
    millersgarage
    neat idea. Looks clean
    Flathead Dave likes this.
  12. spanners
    spanners
    Isn't there a quote that goes "What I used to do all night, now takes me all night to do".
    Tickety Boo and X-cpe like this.
  13. 1971BB427
    1971BB427
    from Oregon
    Doesn't sound like an easy swap back and forth if you have to add or remove clips every time you change to hubcaps or back. But if you don't mind the work, I guess it's not a bad look.
    blowby likes this.
  14. blowby
    blowby
    from Nicasio Ca
    The big ones go in the bed.
    So far the easiest, and best way I've though of is to use the stock VW clips, attached to 1 inch flat stock bolted under the lug nuts. But yeah, that would be funky looking without the caps unless removed. Better would be to weld them to a round clamp around the hub of the spokes, where the cap goes on. One screw to remove.
    Opinions running around 50/50, same with me. I will make the adapters though, otherwise the dog gets new dishes. Also a good way to save corroded Cragars.
  15. Ebbsspeed
    Ebbsspeed
    "I ain't as good as I once was, but I'm as good once as I ever was."
  16. X-cpe
    X-cpe
    Which bed?
    blowby and Deuces like this.
  17. blowby
    blowby
    from Nicasio Ca
    Made three brackets, hold well. Pretty obvious, might paint em black.
  18. Please don’t take this the wrong way,,,,,I truly mean no disrespect .
    I have went back and forth several times and compared the pics with the covers ,,and without .
    I think the covers take away from the looks of your truck .
    The rear proportion to the rest of the truck as a whole is what catches my eye .
    The pic with the covers makes it look like the shirts airbrushed in the 70’s,,,,,,the tires look ballooned and abstract .
    The Cragar wheels look very good as is .
    Yes,,,,I am a fan of Cragar S/S wheels,,,,,and I like covers as well .
    Anyway,,,,,that was my observation,,,it’s your truck,,,,do as you please .
    Again,,,I didn’t mean to be insulting .
    I think it is a cool hot rod as it is !
    Tommy
  19. The37Kid
    The37Kid
    How big is the screwdriver you bent to pull the caps off?
    tommyd and Deuces like this.
  20. blowby
    blowby
    from Nicasio Ca
    Hey no problem, appreciate the input! It's not like I chopped the top 8" or something. In fact with the brackets I made I didn't have to modify the caps, an easy sell for a few bucks loss. But I'll hang in there with them for awhile.
    Fingers fit behind between the spokes, just a straight pull.
    Deuces and Desoto291Hemi like this.
  21. blowby
    blowby
    from Nicasio Ca
    I should also mention that my wheels are 14s, the centers on 15s may be larger.
  22. nrgwizard
    nrgwizard
    from Minn. uSA
    I'm kinda liking the moonies, but then, I'm not much of a Cragar fan.
    Marcus...
  23. hotrodjack33
    hotrodjack33
    I'm liking it too...not a big fan of Cragars either. A pretty ingenious way to change the look of the truck on the cheap.:D
  24. Zuffen
    Zuffen
    from Sydney
    I'd be bothered about the new brackets scratching my Cragars and also would worry about lug nut torque.
  25. 1971BB427
    1971BB427
    from Oregon
    No offense, but I'd never run without the hubcaps and have to see those ugly clips on there. I'd have to remove them anytime the hubcaps were removed.
  26. 57Fury440
    57Fury440
    I like the caps. The way you set it up you can always remove them if you change your mind.
    jimmy six likes this.
  27. blowby
    blowby
    from Nicasio Ca
    Still bombing around with the caps on one side only. I put electrical tape over spokes where the caps contact, hides the little bit of spoke that shows and protects the Cragars, not that they are any prize. The caps have a rolled edge where they contact.
  28. Tickety Boo
    Tickety Boo
    from Wisconsin
    The older I get, The better I was :rolleyes:
  29. Why not leave it like that? Just come up to the car on the side you're in the mood for. You can only see one side at a time, and neither side when you're behind the wheel.
    upspirate likes this.
  30. David Gersic
    David Gersic
    from DeKalb, IL
    Reverend Raymond and the Chain Smoking Alter Boys. And if I’m out past nine, they better have a damn good buffet.
    I kinda like the look with the caps, but not the off look with the brackets.
    fauj likes this.
