Technical Cragar transmission adapter to Desoto Hemi 341cui. What starter do I use???
Discussion in 'Traditional Hot Rods' started by mrjim, Jul 26, 2020.
  1. mrjim
    mrjim
    from Norco Ca
    Starter Question for a Cragar transmission adapter to flathead ford..
    What starter to use????
  2. Andy
    Andy
    Stock. I have that adapter on my 241 Dodge. I use the stock Dodge starter.
    LOU WELLS likes this.
  3. mrjim
    mrjim
    from Norco Ca
    I have a starter to a 276cui but it's does not fit, to tight....
  4. Andy
    Andy
    It should be a big clumsy looking thing with two mounting holes. As I remember from when I built the car, I had to relieve part of the nose to get it to clock around and clear the flywheel. Chrysler used the same starter on a bunch of engines. I think the flat 6 engines used them also. How much is the hole difference? I have a spare NOS adapter and could measure the hole diameter.
  5. mrjim
    mrjim
    from Norco Ca
    Thanx Andy!!!
    That's seems to be the problem...
    Will check and let you know!!
    Thanx JIM.
  6. LOU WELLS
    LOU WELLS
    from IDAHO
    Price Rebuilding You Stock Starter Against A New Hot Heads Starter...Just A Suggestion From Doing This...Best Of Luck...
  7. mrjim
    mrjim
    from Norco Ca
    Thanx Again andy!!!
    Worked, exactly;like you described!!!
    Your'e the man!!!
  8. mrjim
    mrjim
    from Norco Ca
  9. Andy
    Andy
    THANK YOU!!!
  10. You might want to look at a newer 318 starter out of a dakota. These mini starters work in alot of these situations. I have used the for years in gen 1 and 2 hemis for years.
    Lil'Alb likes this.
