Cragar wheel lugs
Discussion in 'The Hokey Ass Message Board' started by 61 chevy, Jan 16, 2010.
  1. 61 chevy
    61 chevy
    jUST GOT NEW TIRES INSTALLED ON MY CRAGAR WHEELS FROM LOCAL TIRE SHOP. CHECKED LUG NUTS TODAY & WASHER UNDER LUGS READS WHEEL SIDE. AM I WRONG OR SHOULD THE WASHER BE REVERSED WHERE THE WRITING IS FACING THE RIM. TO ME WHEEL SIDE MEANS THAT SIDE SHOULD BE MOUNTED AGAINST THE RIM, RIGHT OR WRONG. THANKS FOR ANY INPUT.
  2. You are correct. The guy who installed them is a dip****..
  3. Gasser 57
    Gasser 57
    from New Jersey
    There's lots of em out there. My buddys brother in law is an engineer that makes big money. He once changed a flat on his car (steel wheel) and put the lugs on with the cone facing out. Nothin' shocks me anymore.
  4. Muttley
    Muttley
    Yes, the side that reads "wheel side" should, obviously, be facing the wheel. If you look at the washers they are curved and flatten out to put tension on the lug nut that helps prevent them from backing off. Make sure the washer is between the little nubs on the wheels when installing them or you will have problems. The uni-lug design is a major pain.
  5. 61 chevy
    61 chevy
    it getting to the point you cant trust anbody to work on your car anymore :eek:
  6. 454_4_ON_THE_FLOOR
    454_4_ON_THE_FLOOR
    from Selden, TX
    A buddy of mine had a local shop weld his gl***packs in backwards, I didn't even know you could do that. And they even had front and a little arrow pointing stamped on em.
