Hot Rods Crane Cams Nitro F-560 grind
Discussion in 'The Hokey Ass Message Board' started by 30dodgeboy, Aug 28, 2022.
  1. Anyone have an older Crane Cams catalog that can list the specs for a Nitro F-560 grind?
    Cam is a flat tappet solid lifter, engine family is 51-56 301/331/354 Chrysler.
    Kan Kustom likes this.
  2. bushwacker 57
    bushwacker 57
    1971 Crane Cams Cat. Nitro F-560 IN open 72- close- 108 EX open 108 - close 72 Advertised Dur . 360 AT .050 .294 VALVE LASH IN .032 EX .036 GROSS VALVE LIFT .560.
    Kan Kustom and Bob Lowry like this.
  3. THANK YOU !!
  4. joel
    joel
    Curious. What are you building?
  5. lippy
    lippy
    from Ks
    That is an old grind. Check the cam closely. If you can profile it, do it. Are the lifters matched to the lobes? Like I said check the lobes and the lifters closely for wear. Lippy
  6. slayer
    slayer
    Are you building a new mill for big woody, or just looking to upgrade your curent engine?
