Technical Crane HIT-280-2-NC specifications
Discussion in 'The Hokey Ass Message Board' started by Tickety Boo, Oct 18, 2023.
  1. Tickety Boo
    Tickety Boo
    from Wisconsin
    When his uncle p***ed, a friend of mine picked up a 427 Chevy long block that had a fresh rebuild about 25-30 years ago. While it was in storage the cam lube drained off, also ***embly lube turned into wax in other areas. We pulled the never run hydraulic cam/lifters to re-lube and would like to know its
    specifications.
    Thank You for the help.
    Norb
  2. chicken
    chicken
    from Kansas
    Basic Operating RPM Range: 2,200-5,200 RPM
    Duration at 050 inch Lift: 224 int./224 exh.
    Advertised Duration: 280 int./280 exh.
    Valve Lift with Factory Rocker Arm Ratio: 0.460 int./0.460 exh. lift
    Lobe Separation (degrees): 114
    This is a HIT-280-NC spec....the -2 MAY make it a split duration cam with a bit more exhaust duration. I don't have that spec.
    Tickety Boo likes this.
  3. Tickety Boo
    Tickety Boo
    from Wisconsin
    Thank You chicken , this one has more lift :confused:
    Checked the base diameter and lobe lift with dial calipers tonight to find if there was a difference on the exhaust side
    because of the -2 stamp, probably is not the exact measurement with a caliper but pretty close :rolleyes:
    .304 intake lift x the 1.7 rocker ratio = about .517 gross intake lift
    .320 exhaust lift x the 1.7 rocker ratio = about .544 gross exhaust lift
    Stamped below the Crane name is 13-17-81, thinking the cam was manufactured in 1981.
    M
