Technical Crank handle 51 Merc. How to remove?
Discussion in 'Traditional Customs' started by GTfastbacker, Aug 6, 2022.
  1. Gentlemen,
    i tried to remove the Window handles on my 51 Mercury without success.
    Is it the right tool i use?
    Maybe wrong for these type of cranks?
    I am confused….
    Thank you
    Joe
  2. Mr48chev
    That should be the correct tool, if the spring clip was installed correctly you run the tool in behind the handle straight with the handle.
    Push in on the door panel and see if you can push it far enough to see behind it. To see which way the spring clip is on the handle. It's been 30 years since I sold my 51 so the memory isn't perfect on it.
    GTfastbacker likes this.
  3. leon bee
    leon bee
    My Ford doesn't have those springs, you sure Merc does?
  4. there are no screws or pins in the handles?
  5. leon bee
    leon bee
    I shouldn't say, cause I don't know. Ford, you depress that bezel thing towards door then a little pin is exposed.
    INVISIBLEKID and GTfastbacker like this.
  6. Budget36
    Budget36
    Is it like the little “U” with a few ears on it that sits it a groove? If so I use a shop rag and with “saw action” get them out.
  7. jimmy six
    jimmy six
    I’ve found them is the opposite direction. After pushing in the door panel and wedging it back, I’ve used a thin welding rod with a hook bent at the end.
    5window and GTfastbacker like this.
  8. 49 was the last year for the pin and square shank. I've had them fight me and go to the shop towel to get it done. Seems sometimes when handle keeps falling off a guy will squeeze the clip tighter together and it stays on. Problem is the little ears are no longer out far enough for the correct tool to catch them.
    Bandit Billy and VANDENPLAS like this.
  9. 51 mercules
    51 mercules
    That's the tool I used on my 51.
  10. Some have clips and some have a pin. push the bezzel and door panel in to see what you have.
    INVISIBLEKID likes this.
  11. sideswipe
    sideswipe
    When I was a kid my dad used a screwdriver and a lot of cussing to get them off. Haha
    The good old days.
    VEDETTE and Bandit Billy like this.
