Crank Mounted Alternator Question
Discussion in 'The Hokey Ass Message Board' started by celibaterifle, Jan 4, 2007.
  1. celibaterifle
    celibaterifle
    from Australia
    Has anybody mounted an alternator directly to the crank. A mate is looking into doing this on a current project.
    Anyone see any dramas with doing this?
  2. squirrel
    only problem I see is that it would turn about one third to one half as fast as it's designed to turn, so it won't charge until you get going pretty good.
  3. celibaterifle
    celibaterifle
    from Australia
    Have thought about that - apparently the alternator he sourced starts charging around 1700-1800 rpm.
  4. The other thing is that if it is connected nose to nose, it will turn in the wrong dirrection. I dont have any idea if it matters what dirrection an alternator spins. good luck.
  5. Paul2748
    Paul2748
    Doesn't work when you are sitting still.
  6. Chopperman
    Chopperman
    am I missing something ?
  7. Chopperman
    Chopperman
    I've run GM 1 wire alts in reverse with no problems
  8. Dirty2
    Dirty2
    Alternators dont care which way they turn. But like stated earlier it wont turn fast enough at idle.
  9. squirrel
    alternators generate AC, and use diodes to turn it into DC, so direction does not matter.
  10. Alternator=AC (alternating current)=it don't matter which direction
  11. I believe you're thinking about an alternator running off the driveshaft
  12. I know they rectify AC to make DC so from that standpoint it doesnt make a difference which way they spin. But if the brushes are off set as they can be in non reversable motors and some generators they will wear the brushes out real fast when turned the wrong dirrection.
  13. squirrel
    But the brushes in an alternator contact slip rings....there is no comutator like there is in a DC generator or motor. I woldn't worry about the brushes wearing out.
  14. Dirty2
    Dirty2
    Yep...
  15. Slag Kustom
    Slag Kustom
    it could be made to spin faster with a rubber pulley pressed against the inside of a ring bolted to the balancer.
  16. Phil1934
    Phil1934
    You don't say which engine but Mercrioser built alternators into dampeners. My Merc 224 had one that fit a 289 snout but wouuld need balance added. Low output, but if you don't have EFI etc and don't plan to drive all night would work. Also someone had one for SBC water pump pulley.
  17. mustangsix
    mustangsix
    I tried to do this once, by driving one off the end of the crank, but it just wasn't turning fast enough to work. If you look at the stock pulley ratio you can see that they are usually spinning 3 or even 4 times crank rpm. When the engine is ticking over at idle, the alternator may be going 2-3000 rpm already and might hit 15,000 rpm when you rev the thing!:eek: but that's the way they work and an alternator that's direct drive from the crank with no step up in speed might not put out enough power.
  18. celibaterifle
    celibaterifle
    from Australia
    Thanks mustangsix. That's been our main concern. Did it put out any charge at all? This won't be a daily driver and odds are it will end up being rarely driven knowing who it's being built for. So would a crank drive have enough output to keep things running over a weekend jaunt?
