Technical Crank Polishing
Discussion in 'The Hokey Ass Message Board' started by seb fontana, Apr 12, 2023.
  1. seb fontana
    seb fontana
    from ct
    If crank journals are 1" wide how wide should the sanding belt be?
  2. Jagmech
    Jagmech
    Most crankshaft polishers are 1" wide , 3/4" is also used, results depend on skill of operator.
  3. 19Eddy30
    19Eddy30
    from VA
    Some use the width of total journal width.
    Some use width of bearing contact,
    I have also used shoe string and Emery cloth ,
  4. ken1949car
    ken1949car
    from chicago
    Shoe string, wet/dry 600 or 1000 grit sandpaper and WD40.
  5. Deuces
    Deuces
    Yep and keep a clean rag and micrometer on hand to check your progress....
  6. PackardV8
    PackardV8
    https://i.machineryhost.com/d336c41d7cdbeadaa2dfea98a7bbb2ad/32acb52b9e.jpg
    It's so difficult to control and maintain flat surface, some say impossible, to actually remove material by hand from a crank journal and not make it worse. Most crank grinding shops no longer use belt polishers. The current technology uses micropolishing paper to remove the "fuzz". While dimensionally more accurate, ironically, the micropolished journals are not as shiny as the belt polished.
    jack vines
    1934coupe likes this.
  7. ekimneirbo
    ekimneirbo
    You might look at the "scalloped" belts on Ebay. They help by not making the belt have an "edge" as it rides onto the fillet radius.
