Technical Crankcase ventilation, breather question
Discussion in 'The Hokey Ass Message Board' started by wdglide, Jan 1, 2021.
  1. wdglide
    wdglide
    I'm working on the venting for my hemi. Its probably under 450 hp with dual quads. I have the PCV valve setup. My question is:
    How much "intake" is required on the breather side of things?
    I do not want to cut my valve covers and have no room on my valley cover for mini breathers. My oil fill cap is non-vented.
    I'm planning on putting a barbed fitting in the vent cap (or valley pan) with a hose to a one-way valve (similar to venting a gas tank). I'm concerned whether or not a small 1/4" vent line is enough.
  2. wdglide
    wdglide
    A photo of the motor...
    Bob Lowry likes this.
  3. Fordors
    Fordors
    From my recollection of engines I’ve had a 350 Olds used a tube of about 1/2” ID drawing air from the air cleaner and the 396/375 BBC was a bit larger at maybe 5/8” ID. Your 1/4” seems small, most seem to use a larger size on the fresh air side than the PCV side.
  4. Bob Lowry
    Bob Lowry
    Yep, on my SBC's I use a 1/2" fresh air hose, sourcing from the underside of the air cleaner. On my BBC
    motors I typically use a 5/8" hose. Both are ID. Bob
  5. jimmy six
    jimmy six
    I’d like to see a photo of your oil filler. I use 1/2”-5/8” heater hose to a fitting I attached to the rear air filter.
  6. wdglide
    wdglide
  7. 73RR
    73RR
    If you look back at 60s-70s setups you will see that the pcv is on the opposite, or at least distant, side of the engine.
    If you put a pcv at the back of the valley cover and the vent at the front then you will simply pull fresh air across that short distance as that will be the path of least resistance. In the oem Hemi design there was/is a rubber seal separating the oil fill side from the down draft tube side that caused air to flow down around the cam tunnel and back up.
    In some past projects we have put a vent tube in the side of the front cover above the fuel pump and that seemed to be useful with a pcv in the downdraft tube opening.
    Nice shop btw.
    Dan Timberlake likes this.
  8. wdglide
    wdglide
    Well that’s exactly what I’m planning. Vent the front and pcv the rear of the valley cover. You bring up a great point, but I’m a bit committed at this point. Thanks.
  9. Dan Timberlake
    Dan Timberlake
    Yeah, for best sludge and corrosion resistance engines should not just be "vented" with a breather or three. Crankcases should be ventilated, and the longer and more inclusive the flow path ( head > crankcase > the other head ) the better.
    Even some modern engines have gotten it wrong, with sludge related recalls the result.
    Some Toyotas and Mopar v6 come to mind.
    wdglide likes this.
  10. wdglide
    wdglide
    You changed my mind @73RR . I'll run mini Offy breathers on the front side of the valve covers. Seems like a fair compromise.
