Crappy Howell's Model T patch Panels
Discussion in 'The Hokey Ass Message Board' started by chaddilac, Jan 2, 2008.
  1. chaddilac
    chaddilac
    Anyone else have any problems with Howell's cowl patch panels, they don't match the A pillar worth a ****..... What did you to do fix them?
    Got my cowl front nearly done though....
  2. manyolcars
    manyolcars
    I figure I can make poorly fitting parts as well as Howell can, so I usually make my own.
    Just keep welding on metal til you get there
  3. chaddilac
    chaddilac
    I bought them before I had the tools/knowhow to make them, I'm still mad though.
  4. chaddilac
    chaddilac
    Anyone else have this problem?
  5. Never delt with them, but I'm very curious about the 26-27 t roadster door skins they are offering?!?
  6. SaltCityCustoms
    SaltCityCustoms
    It looks like your going to have to add some material to them to make them fit, or just make your own if you have the tools.
  7. i haven't heard great things about their stuff but one thing to consider is the tolerances on the orginal cars. You get plus or minus 1/8" anywhere on my T when comparing one side to the other ...
    for the part you showed i'd cut it in half and move the curve closer to the pilar. Then fill in with a strip. that will get you close enought to finish the correction by adding some material by welding.
  8. nailheadroadster
    nailheadroadster
    Chad!!! What's goin on man?
    Just weld that bad boy on and fill the gap with a buncha bondo. That oughta do 'er! LOL
    Show all these HAMBers how sweet that T of yers is turnin out!!! C'mon, post some 3/4 views so I can start droolin and get all jealous again!!
    Catch ya later, Dave
  9. WhoDoYouFink
    WhoDoYouFink
    I was about to order a set of these along with some other panels I need. Now I am having second thoughts. I also need the rear quarters, door skins, and the filler panel below the rear trunk lid. Any idea how these fit?
  10. Mike B
    Mike B
    I just posted on this topic yesterday. Howell's that is. Their customer service ****s!! The recent patches I have gotten ****! Nothing but a h***le. The most recent panels I received were the 32 truck corner patches. They were terrible. I wouldn't have had a big problem with it except they don't answer the phone and don't return emails and if you DO get through they just promise you something and string you along. I have taken my business elsewhere and I pay a little more but I get a quality peice within a reasonable amount of time and someone to ***** at if they are wrong. :) Just my experience. I am sure some people have been happy with them.
  11. hanginlow58
    hanginlow58
    hmmm, I got lucky I guess, I have used there door skins for 34 ford pickups and just replaced the cowls on my 29 and I was very happy.
  12. oldsmolet
    oldsmolet
    yeah i ordered cowl patches and door bottoms. Fit great from what i can tell so far. Guess im just lucky!
  13. Robert gilbert
    Robert gilbert
    from boston
    i used there door skins and they fit nice , then used a rear patch panle and had the same thing happen i cut it in hafe and added metal .
  14. chaddilac
    chaddilac
    Well it isn't as easy as just adding metal, as the gap is 1/16" at the top and 1/8" at the bottom and the arc in it doesn't even fit the same!
    For those guys who've bought them and haven't installed them, wait till you get it cut and ready to tack!!! Then the firewall flange is 1/4" short as well!!!
    I can tell you the Rear pan fit fine, but I haven't gotten to my other patch panels yet!
  15. mcc7
    mcc7
    from austin
    if you would like a set of cowl patch panels or anything else i can make them and they fit good. i make alot of model t parts please call me 1 507 438 6635 or go to www.mowercountycustoms .com and see some of my work there a coupe i have made from scratch thanks john
  16. chaddilac
    chaddilac
    Do you make the belt line section? I need that also along with the rear corners at the bottom below the trunk pan....
  17. Harrison
    Harrison
    I bought cowl patches & an RPU back panel from Howell's 4 years ago & the stuff fit like a glove. I had the rear panel R&R'd in under an hour.
    This was 4 years ago though...
    JH
  18. I had problems with an EMS rear pan for my 38, it was a good 3 inches too narrow and none of the swage lines matched up!
    For any Aussies out there AVOID 'Old Tin' A model parts.
    I was guaranteed they were the same as original parts. When I got my RPU body rear it was almost an inch deeper on one side than the other, the swage at the top was 1/4 inch too deep on one side and 1/4 inch to shallow on the other, the curve on the body left an inch gap in the center of the door.
    I was told that the swages in the back would be the same as original A, not likely, there were two horizontal swage lines that once went completely across the rear section. So that they ended about 5-6 inches from the side's they were hammered flat with no shrinking!
    Then to make things worse it was so twisted that sitting flat one side sat a full foot higher!
    I complained and they took no notice, had a mate who is well known and owner of one of our biggest hot rod shops contact them about it letting them know if they didn't fix it every one would know about it.
    They sent another but it was not much better than the first, just not as twisted. **** 'Old Tin'.
  19. I had the same problem with the 26/27 lower cowl patch panels I got from Howell's. I put them in but I was not satisfied. Don't have a fix worked out yet. I'll post something when the job is done.
  20. Tall Tom
    Tall Tom
    from Austin MN
    I can vouch for John (mcc7) - posting number 15 on this topic. He does really nice work and can build you any piece you want. He made and installed the panel under my trunk lid on my 26 T coupe and it turned out REALLY NICE!!!!! A good guy too, no h***les.
  21. gear27
    gear27
    Ordered a t decklid fit great but they are difficult to get a hold of
    and it took nearly 7 weeks to get it! Every time I called they said it
    was shipped but they were never able to get me a tracking number
    I the future I would try another source.
    27
