Hot Rods Crate engine help.
Discussion in 'The Hokey Ass Message Board' started by Bob Seward, Jun 2, 2015.
  1. Bob Seward
    Bob Seward
    Installing a Chevy crate engine in my '36 Ford, the old one had a 2 barrel carb. I am going to upgrade to a 4 barrel. Any suggestions, Holley or Edelbrock? It is strictly a driver, no racing or high speeds, just cruising.
  2. oldrelics
    oldrelics
    from Calgary
    quadrajet :)
    norms30a likes this.
  3. BigDogSS
    BigDogSS
    from SoCal
    ^^^^ x Two!!
  4. corndog
    corndog
    from Indiana
    Not Q-jet for me! Edelebrock with electric choke and you will never be happier!
    pat59, Hot Rod Nut and harpo1313 like this.
  5. I have done ok with Edelbrock/AFB's but recently had problem, apparently due to the Edelbrock's sensitivity to too much fuel pressure.
  6. millersgarage
    millersgarage
    Edelbrock would be fine. Depending on the intake you'll want to get a phenolic spacer, or the floats will boil when you park it.
    Also adjust the float, even though they say you don't have to.
    Hot Rod Nut likes this.
  7. 4thhorseman
    4thhorseman
    from SW Desert
  8. i.rant
    i.rant
    1. 1940 Ford
    The Edelbrock with electric choke # 1406 is hassle free,you won't be sorry.
  9. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    I've used the Edelbrock 500CFM Thunder carb with electric choke and the early style Edelbrock intake with the oil filler tube on several Chevy crate engines with excellent results.
