History Crazy shit at the junkyard
Discussion in 'The Hokey Ass Message Board' started by Ifitaintbroke, Oct 6, 2025.
  1. Ifitaintbroke
    Ifitaintbroke
    Whilst on another junkyard date with my fiancé, I stumbled upon a Ford F1 with a peculiar v8 swapped in that I couldn't identify. The lady examined the block, and found it to be aluminum. Yall, we found a Buick 215 v8.
  2. squirrel
    I think it's an Olds, though.
    hrm2k, lake_harley, 6inarow and 12 others like this.
  3. HOTRODPRIMER
    HOTRODPRIMER
    The 215 aluminum brock was used in the Buick Special in 1961.
    I think Pontiac & Oldsmobile both used the aluminum V8 from 1961 -1963. HRP
    hrm2k, Tow Truck Tom, SS327 and 4 others like this.
  4. swade41
    swade41
    from Buffalo,NY
    Cleaned up it would make a nice coffee table
  5. Ifitaintbroke
    Ifitaintbroke
    Depending on how much they want for it, I'll get it just to have. These are pretty rare these days I'm sure.
    hrm2k, SS327, doug3968 and 2 others like this.
  6. oldiron 440
    oldiron 440
    Leaves were optional
  7. squirrel
    The valve covers are Olds. The Buick version looked more like a nailhead.
    Subtle differences, most guy don't even know they are two different engines.
  8. Sharpone
    Sharpone
    Would make a cool T Bucket engine
    Dan
  9. 31Apickup
    31Apickup
    The Olds version used their own heads whereas Buick had their own that looked nailhead like. Short blocks are the same although the pistons may be specific to the heads used.
  10. Sandcrab
    Sandcrab
    I ended up with around seven of the 215's by buying C list piles for a couple hundred dollars. I ***embled one runner so far and working on another that will be a 300 cu in using a 300 crank. Plus a Rover which started as a 215 cu in but grew to 300cu in plus in England.
    It is a neat little engine and fit the Ruby which is what prompted the ac***ulation.
  11. Ifitaintbroke
    Ifitaintbroke
    We went to another junkyard and things only got crazier. I quite literally fell to my knees before this automotive royalty.
  12. sunbeam
    sunbeam
    Worth twice as much if the air cleaner was still on it.
  13. sidevalve8ba
    sidevalve8ba
    And if it was a Twin-H you would really have something!
    Sharpone, LCGarage, j hansen and 5 others like this.
  14. I had a 215 in my '62 Skylark....great little engine!!
    Sharpone, Ifitaintbroke and 49ratfink like this.
  15. 49ratfink
    49ratfink
    had a friend of a friend who hated American cars. he bought a new Rover with the Buick motor. he had no idea until I mentioned it, but I made sure to point it out every time I could so he would remember. his only American car he ever owned was a Vega, maybe he should have put a 215 in it.
  16. Pav8427
    Pav8427
    2 door version of one just 5 miles south of me. About the same shape. Sitting way down in the dirt. Pretty sure whole botton is bout gone.
    A 48 convertible just 3 miles south of that.
    Not for sale. (Uncle was murdered in it in the early 50's. )
    SuperKONR, tractorguy and Sharpone like this.
  17. Ifitaintbroke
    Ifitaintbroke
    No offense to your friend, but if someone picked a Vega as the only American car they'd buy, there's nothing I can call them other than an idiot.
  18. sidevalve8ba
    sidevalve8ba
    If your friend owned a Vega I can understand why he was sour on American cars.
  19. Ifitaintbroke
    Ifitaintbroke
    If that's the order it happened in it makes sense, but the mental image I got was of someone refusing to buy American cars for decades, and then finally settling on a Vega.
  20. skooch
    skooch
    As a kid I had a friend who put one in his Vega, stupid fast.
  21. Toms Dogs
    Toms Dogs
    from NJ
    Mickey Thompson attempted to qualify a 215 Buick engine and a 215 Oldsmobile engine in his rear-mounted engine cars, at The Indianapolis 500. *Neither "Qualified"
    :( :rolleyes:
  22. Dave G in Gansevoort
    from Upstate NY
    Back in the 60s, Repco-Brabham sohc V8 formula 1 engines were based on the Buick-Oldsmobile aluminum block, however they were much modified and that was the only part of the engine used for the F1 engine. The heads were 2-valve sohc crossflow, the crankshaft was EN40 billet steel, and single plane. One of the most unique features was the dry sump system, which used a two stage pump, and the oil pan/sump was cast with a p***age that was the oil pickup for the sump. There was a shuttle valve system that moved front to back under braking or acceleration that opened the appropriate port in the pan for where the oil would be. Only using one return pump section saved them a few horsepower. It was also successful, winning the ***le in its first year of racing.
    Toms Dogs, LCGarage, alanp561 and 6 others like this.
  23. The 215 was a great little engine but the dual path 2 speed automatic was ****!!:confused:
  24. chopped
    chopped
    Buddy of mine in his Vega going down the highway. Think the guy next to us is yelling you have a flat tire, what he really said was the car's on fire. Common for the Vega.
  25. Phillips
    Phillips
    Gurney did qualify in ‘62 with Mickey’s aluminum Buick powered car. Didn’t finish.
  26. Paladin1962
    Paladin1962
    About 5 years ago I was walking through the pic-a-part in Charleston SC and there was a Daimler 250 (actually a Jaguar Mk2 body) with the Daimler 250 hemi v8 in it. I don't know if it was stuck/busted/blown but if i'd had the time to mess with it I would have bought it just to HAVE it...
    Sharpone likes this.
  27. stuart in mn
    stuart in mn
    I've often thought a V8 out of a junked Range Rover would be a good hot rod engine. Get rid of the complex FI system and put on a four barrel carb and manifold and some finned valve covers. If you were obsessive you could even polish the heads and block. :)
    alanp561 and Sharpone like this.
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    yup the valve covers on the buick are more like a nailhead
  29. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I owned a '62 convert briefly, with the flexible bendy driveshaft and a transaxle.
    Weird.
    SS327 and Sharpone like this.
  30. Clydesdale
    Clydesdale
    As a UK resident I find it very amusing all this enthusiasm over Rover V8s haha, maybe I should just round a load up and ship them stateside. Anyone up for a RV8 > SBC trade :D
