Creaky front suspension
Discussion in 'Off Topic Hot Rods & Customs' started by Klaus61, Jul 23, 2024.
  1. Klaus61
    Klaus61
    Recently enlistee around here. I’ve got a ‘36 Ford Pickup with an independent front suspension that’s a bit creaky. I suspect it’s a least nine to ten years old, only about 1000 miles in that time. I have no history on the building of the car, although it appears to be either an outstanding amateur or a hot rod shop. I posted a photo of the truck on the introduction section, if anyone knows, or was a previous owner, I’d welcome any information! I found a listing for it from 2015 in San Francisco, had an Illinois ***le when I bought it.
    Drives straight, steering is pretty tight. Already lubed the ball joints, helped a bit.
    My question is how to ID which IFS I have and if the bushings/rebuild kits are interchangeable a**** the various aftermarket IFS.
    My apologies if I’ve posted in the wrong area.
    Thanks!
    Craig
  2. chryslerfan55 likes this.
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    Moved to the off topic forum. Pinto front suspension is not allowed on the main forum
    Desoto291Hemi likes this.
  4. Klaus61
    Klaus61
    What makes you think it’s a Pinto suspension?
  5. Moriarity
    Moriarity
    SUPER MODERATOR
  6. '29 Gizmo
    '29 Gizmo
    from UK
    If its polybushed the bushes are probably the cause of the creaking. Pull the bolts and inner steel sleeves. Grease and re***emble.
    Black Panther likes this.
  7. Klaus61
    Klaus61
    Thanks
  8. Klaus61
    Klaus61
    Geez, I’ll get back on the yellow footprints.
    You all have fun.
  9. gene-koning
    gene-koning
    Or you could have just gone to the off topic part of this board and enjoyed a new experience.
    Really, Moriarity, you could have easily added that the Off Topic part of the HAMB is for non traditional stuff. Explaining to him why you mover it there would be more helpful the blasting him for an off topic ride.
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    That is what I told him when I moved it
    TA DAD and JohnLewis like this.
