Projects crminal coupe, an attempt at a 31 A build
Discussion in 'The Hokey Ass Message Board' started by crminal, Aug 13, 2013.
  1. crminal
    crminal
    It's the shot that makes it look like that. Actually fits comfortably, but right there.
    I'll save your suggestion for a non-mechanical application ;~)
  2. crminal
    crminal
    So getting back to how the steering box went in, I decided to use the same location as the stock box. Hoping to use a stock shaft in a tube type column. We'll see.
    Plugged the stock hole
    Welded it in
    Ground and drilled a new hole for the sector housing and plugged the stock mounting bolts
    Once welded up, made 3 new holes for the mounting flange
    Thanks to NealinCa for machining the sector housing and providing this mounting flange which I will tack to the housing when correctly positioned.
  3. NealinCA
    NealinCA
  4. RPMhotrod
    RPMhotrod
    from Philly, PA
    Great work criminal! keep it up!
  5. crminal
    crminal
    Thanks for the good vibes, Neal and RPM.
    Pulled the 292 engine and got it on a stand to strip it down. Looks to be in pretty good condition (bored 30 over). Pulled the heads to take to Tim for a dose of his "magic touch". They are 113 heads and should be a good start. Not planning anything major, just head work, oiling mods, cam, stock large bore 4 bbl and Holley 600. We'll see where I end up ;~)
    Got some Lincoln front brakes from Derek at Boling Bros when I was at the CHHR. Also got my 40's steel rear wheels widened to 7" by Wheelkid.
    2 good guys to do biz with.
  6. Marten
    Marten
    Very complete building thread...thanks! Looking good so far
  7. 60 Belair
    60 Belair
    Nice looking coupe! Great build!
    Andy
  8. Looking forward to getting the heads. And the other stuff you have for me. :D
  9. crminal
    crminal
    What could you possibly be referring to?
    Oh, this looks a bit more comfy,
    150 at Elmo! ;~)
  10. Thanks! Nice to see a bigger picture than my phone.
  11. rob lee
    rob lee
    from omaha,ne
    Nice work man,looks like a good plan!
  12. ty johnson
    ty johnson
  13. crminal
    crminal
    Appreciated guys!
    So, speaking of good plans:eek:, the steering box, oil filter adapter, manifold all in the same piece of real estate just isn't going to work.
    Moving the steering box up on top of the frame and back a bit makes all the difference. It needs to be there. Looking through one of Hitchikers old threads, I found a solution by member "Paulsec" using a VW bus steering mount (hey its from a late 50's early 60's so its vintage ;), right?
    I located the mount and they are inexpensive. Maybe I can get NealinCa to turn my sector shaft down a bit more.....:eek::eek::eek:
    Thoughts are welcome
  14. Texas Webb
    Texas Webb
  15. NealinCA
    NealinCA
    If you want to send the box back, along with the VW bus mount, I can re-machine it. I can also credit you back on the flanges. It would probably just cost you the shipping.
    Neal
  16. crminal
    crminal
    Thanks, you're a good dude. We'll see how this plays out......
  17. boutlaw
    boutlaw
    Nice work crminal, looking great and no doubt you're having a blast...subscribed.
    BOutlaw
  18. crminal
    crminal
    Thanks Boutlaw! Being new to this, it has it's challenges but is a blast. How bout a shot of that FE of yours?
  19. crminal
    crminal
    Got a bit more done, actually for me a small victory.
    Got the holes all filled and did some frame rail clean up.
    Then after hours of fitting this and adjusting that, think I got it all to fit by using the steering box mount I mentioned previously.
    Here is how it all looks...
    Steering, exhaust clearance looks good...
    So pretty happy about all this! Time to move forward ;~)
  20. Squablow
    Squablow
    Steering box mount looks nice, looking forward to seeing more of this build.
  21. Looks like it will work!
  22. crminal
    crminal
    Yeah, I think I can put this one to rest. Also pretty happy about the idea of having a McMaster built engine in my future! Gotta get this baby ready ;~)
  23. rob lee
    rob lee
    from omaha,ne
    No ****!,lucky man.Keeping a eye on progress,Rob
  24. RPMhotrod
    RPMhotrod
    from Philly, PA
    Love it! Looking forward to seeing more!
  25. I'll see you in a couple of days to pick up the core. Have coffee please. ;):D
  26. NealinCA
    NealinCA
    The VW bus bracket looks like it worked out well. That is a tight fit, but looks great
    Neal
  27. Good to see you and the Coupe yesterday! I think you should share you other Coupe with the rest of the guy. *****in' Banger!
  28. Looks like we may have a power plant for you soon. :D
  29. BCCHOPIT
    BCCHOPIT
    How did I not see this... Looks like another late night for me.
  30. crminal
    crminal
    Been watching your videos of you tearing up the countryside in your beautiful Tudor. Especially the sound that engine makes tearing on by. Then this.......
    Tim, I'm stoked!
    Thanks ;~)
