Projects crminal coupe, an attempt at a 31 A build
Discussion in 'The Hokey Ass Message Board' started by crminal, Aug 13, 2013.
  1. crminal
    crminal
    Hey, good to hear from you. You still making those fine intakes? Been off the banger board for a while ;~(
  2. BCCHOPIT
    BCCHOPIT
    Yes...
    But now I am working one gathering parts for a model A Tudor. I picked up a Y block for it. Keep posting lots of pics
  3. burnzy37
    burnzy37
    Did you decide to keep the banger? I remember checking it out in the cl***ifieds some months back...very cool.
  4. Cool! More Y-Block As! Just what the world needs to keep peace and order. :D
  5. crminal
    crminal
    I've seen your video.
    Peace and order? Really? HaHa ;~)
  6. Got something for you.
  7. I'd heard about the build, but I'm just now stumbling across it. Very good info, and I really appreciate the problem solving and attention to detail.
    Should be sweet, if you like Y-blocks...
    :cool::beer:
    Sent VIA top secret BIGREDTODD Mobile HQ
  8. crminal
    crminal
    Hey BRTodd, thanks for the kind words man. Maybe I'll see ya at GNRS meet and greet. Wear those flip-flops! BTW, yeah, I think I'm respectful of the Y-block.
    McTim, DAMN! She's a beauty! Your efforts and knowledge are very much appreciated. Never though I'd be fortunate enough to have a power plant from the Yblockguy ;~)
  9. crminal
    crminal
    Moving forward, got a bit more done;
    Made a hoist in my barn and got the body off to start on ch***is stuff
    My first set of bones!
    ImageUploadedByH.A.M.B.1391401248.204120.jpg ImageUploadedByH.A.M.B.1391401293.883620.jpg
    Bracket to set the bones inboard a bit for wheel turning clearance
    Reshaped the spindle to accept new Lincoln style backing plates.
  10. Great looking work Bryan! You are a craftsman. Glad to see someone got some work done this weekend.
  11. 1931fordtruck
    1931fordtruck
    I got some work done on mine yesterday. Got the wishbones cut apart and started mocking up the front end.
  12. crminal
    crminal
    Weld them bungs in! ;)
    Quite satisfying when it all works out :cool:
  13. MTR-HD-Ordie
    MTR-HD-Ordie
    Looking good!! Glad your making some progress!
  14. 1931fordtruck
    1931fordtruck
    Its pretty satisfying to see the progress I have made so far. If I keep going the way I am, I should have her on the road by my dead line date if not sooner.
  15. inkstain27
    inkstain27
    Nice work, Subscribed!
  16. RPMhotrod
    RPMhotrod
    from Philly, PA
    excellent work criminal!! Bones look great!
  17. daddio211
    daddio211
  18. crminal
    crminal
    Thanks INK and RPM, good feedback inspires ;~)
    Hey Daddio, great meeting you and your better half! Nobody ever shows up to the meet and greet on time ;~)
    Yeah, met up with Tim for a few minutes. Great show indeed.
    Keep on with your build man! Looking good.
  19. Lancer
    Lancer
    Great build and a little deja vu on the Y-Block pics ha ha. My pistons are not flat on top though.
  20. crminal
    crminal
    Oh that's funny! Thinking the same thing looking at your pics ;~)
    And yes, you've got a bit more poking out the top......
    Enjoying your build as well and will buy the shirt when that graphic is done!
  21. crminal
    crminal
    Getting some more work done. A lot of "finish up" things for the ch***is.
    Way back in this thread, I posted a pic of a clearance problem with the driveline yoke and a crossmember. I cut a semi-circle out of the tube, formed a plate and welded it in to restrengthen the tube.
    Very pleased with the clearance now.
    Next is to start working on a K member of sorts and a transmission mount.
    And..... I've got steering now!
    Limeworks made me a new shaft with keyway for '40 style wheel and pressed the worm gear on. Also a nice column.
    Tire clearance is great when turning and it looks like its going to work well.:D
    dana barlow likes this.
  22. Things are really looking great. Nice stout plate there where you clearanced the ladder bar x-member.
    You probably already know this, but make sure you install the fron ladder bar bolts from the outside in rather than the way they are now. I've made the same mistake, and it makes life miserable to remove them otherwise.
    Looking forward to seeing more progress!
  23. crminal
    crminal
    Hey Todd, never ***ume I've got this completely figured out ;~)
    I appreciate anything I can learn from.
  24. Nice car! I also put a 292 in my model A. I used a '57 Chevy steering box and mounted it above the frame also.
  25. scoggman
    scoggman
    Man!!! That is lookin sharp!!! Keep it up!
  26. dana barlow
    dana barlow
    from Miami Fla.
    Steering an cross is looking super!
  27. funk 49
    funk 49
    Lookin' good man. Sorry I missed you at Viva. Keep up the good work.
  28. crminal
    crminal
    Thanks Dana, thinking it will work well
    Me too, it was a great show!
    Haven't done much lately but I'm getting my trans mount in place and ready for boxing. I'd been thinking about how I'd secure the nuts for the body mounts. Searching the Hamb I saw lots of great ideas but here is my version...
    I'd use rod coupling nuts. This way I'd have lots of threads in case of a cross thread or any other mis-hap.
    Using a step drill, I made a hole that partially had the next larger opening in the same hole. Then tap the nut into the interference to grip the nut
    This held it well in place and actually engaged the frame.
    Weld the top flush, then welded a "leg" on the bottom for strength. Not rocket science but hey.
    Boxing soon.
    y'sguy, dana barlow and daddio211 like this.
  29. Glad I stumbled across this thread! What an amazing build, keep up the great work. I'm definitely going to follow along.
  30. BCCHOPIT
    BCCHOPIT
    And then what????
    WACCUSTOMS.COM
    mctim64 likes this.
