Technical Crooked leaf springs
Discussion in 'The Hokey Ass Message Board' started by cerial, Oct 11, 2015.
  1. cerial
    cerial
    from Michigan
    I have a 51 3100 axle I am using on a custom build. I am building a tube frame so have no reference. I bolt up my superslides meant for this axle and they are not square with the front axle.
    I have the bolts loose and can wiggle the springs a bit. The closest I can get them is with the rear 29.5 outside eye to outside eye and the front is 27.25 outside eye to outside eye.
    Is this right?
  2. readhead
    readhead
    The frame on the '51 is not parallel. The pads on the axle reflect this.
    Cosmo49 likes this.
  3. gnichols
    gnichols
    from Tampa, FL
    Many leaf spring cars have "non-parallel" parallel leafs. No biggie. Gary
  4. cerial
    cerial
    from Michigan
    Thanks I thought that was the case. But, I still had a "what the" moment when I first bolted them down.
  5. Rex_A_Lott
    Rex_A_Lott
    Its fairly common for them to be "toed-in" at the front. This helps a little when you are depending on them to keep the rearend from moving side to side.Just a way to take up the slack from all the mounting bolts, shackles etc.
