Crossram on the street?
Discussion in 'The Hokey Ass Message Board' started by blacksheep55, Dec 27, 2012.
  1. bcowanwheels
    bcowanwheels
    600cfm vac***e secondary holley carbs would work nice, 450's and 500's are too small and the vac. Secondarys wont force feed the engine, it will only give it what it needs.
    Bob
  2. CutawayAl
    CutawayAl
    from MI
    600 CFM carbs on a cross ram is equivelent to a 1,200 CFM carb on a 180 degree/dual plane manifold. :eek:
  3. MeanGene427
    MeanGene427
    from Napa
    Exactly the way mine was, I only had to bump the primaries up a couple sizes and the 3.5 PV's and get the linkage and idle stops exactly the same, and it was a bear for throttle response- actual experience, not "oughta be". Great driveability, and the howl from the carbs anywhere above 3500 was something :eek:
    With your compression, cam, and intended usage, I wouldn't even waste time with some vac carbs, just amp it up- mileage isn't a consideration. Drop the gears down a bit and hang on :D
  4. 383man
    383man
    from Md
    I would run it if you want too. Lots of Mopar guys run them on Max Wedges and Hemi's. I thought about one on my 63 Plymouth but cash is tight right now and it seems a nice modern single carb intake and good size carb will make more power so I run the Indy dual plane and it works great. But I see alot of guys running crossrams and they say they have no problems once they dail it in. And it does have a great WoW factor. Ron
  5. mdcolby
    mdcolby
    go for it! They work well but it takes time to get it dialed in.
  6. blacksheep55
    blacksheep55
    from jasper ga
    Sure thing Tommy, We brought our front engine a/fuel car up there last year but didn't get to make a p***. What a bad*** event though. We also go up and mess around at some of the shows in Pigeon Forge, really just a weekend BS session.
  7. gimpyshotrods
    gimpyshotrods
    I ran on on a hot SBC 350 on an OT Malibu (69) back in the 80's. Two Holley 390's. Worked fairly well. If I had the tuning skills and tech that I have now, I'd bet it would be a real screamer. The car was ****, but I wish I still had the manifold.
