1952-59 Ford Crown Vic front subframe
Discussion in 'Off Topic Hot Rods & Customs' started by 55fordcust, Jun 4, 2015.
  1. 55fordcust
    55fordcust
    from ohio
    Anyone ever swap one of these over to a Customline or any other 50's Fords? Came across a free one with brand new rack and brand new springs up front.
  2. silverjk
    silverjk
    from Houston
    I know it is a common swap for F100s, which makes me think the width wouldn't be right without modifying it heavily. (I've heard the beauty of the swap on the F100 is the crown vic IFS is very close to the stock width and nearly bolts in)
  3. Edsel58a
    Edsel58a
    05 Crown Vic
    Track width with stock wheels - 63 1/2
    Hub to hub surface - 67 1/2
    Outside of tire - 71 1/4
    For comparison, 1950 Ford has a 56" track width, 56 Ford has a 58" track width. 57 Ford has a 59" track width
    Hope this helps
  4. 55fordcust
    55fordcust
    from ohio
    I did some research on this last night and it looks like it's next to impossible to do. Would have been cool to do but not looking like it now! Thanks all!
  5. Edsel58a
    Edsel58a
    Okay.... this may not be the best idea or even possible. Could the front frame ***embly be cut and narrowed? A different rack would be needed, but should work.
  6. JeffB2
    JeffB2
    from Phoenix,AZ
  7. fordsbyjay
    fordsbyjay
    from Lafayette
    It fits right into the 67-79 F150's with hardly any modifications. I thought about looking at the Explorer front end (narrower) but I have one of those and they have crazy bump steer.
  8. JeffB2
    JeffB2
    from Phoenix,AZ
  9. 55fordcust
    55fordcust
    from ohio
    For the amount of work, I think I may just keep the y block in the car until it sells or quits chugging along. I just want to be able to drive the car again. My plan is by next spring to be driven!
  10. JeffB2
    JeffB2
    from Phoenix,AZ
    If your intent was to do an engine swap,that can be done with over the counter parts using a 302/5.0 or 351C with an AOD or C4. Improving handling is also a no brainer,all the info can be found in our FAQ section.
  11. Edsel58a
    Edsel58a
    Yea, just drop in a small block using Fox body Mustang mounts.
  12. Edsel58a
    Edsel58a
    On that 50 Ford, a 62.8 (Torino) front track on a car that had a 56" (50 Ford) track width..... Hmmmm.... it does not look as bad as I imagined it may
  13. 55fordcust
    55fordcust
    from ohio
    It will be getting a sbf after the air ride and 4 link are done and working fine. just a matter of time and money and I have been lacking both recently.
  14. mikhett
    mikhett
    from jackson nj
    Theres nothing wrong with the original 56 IFS.Why go to the bother cutting up your front suspension?
  15. jhaymon
    jhaymon
    it doesn't fit. I've already tried. The problem isn't cutting the frame because i don't have a single issue with chopping up an old frame if it gives me safer more dependable car. It's the wheel backspacing you need to clear the calipers. It's too wide to put the same backspacing on the back having to cut wheel openings out of the quarters.
    .....I guess it would be ok if you were after the g***er look without the 5 mile turning radius.
  16. mikhett
    mikhett
    from jackson nj
    I rebuilt my 56 front end with all new parts.Rides great!
  17. HOTRODPRIMER
    HOTRODPRIMER
    I did the same thing with our '54 Ford. HRP
  18. junkyardjeff
    junkyardjeff
    I can drive my 55 80 all day long with a rebuilt original front suspension with disc brakes.
