CT Barn Find 1930 Model A Build
Discussion in 'The Hokey Ass Message Board' started by speters, May 10, 2012.
  1. speters
    speters
    Working on getting it running and doing a few other fixes.
    Already done...
    Cleaned it out
    Took out headliner
    Purchased battery and tray parts
    Put is new rear gl*** with weatherstrip
    This week I need to..
    Completely new wiring
    New Bulbs
    Headlight lens
    Taillight lens
    Repair front engine mount
    Go through brakes
    Grease up ch***is
    Replace belt
    Flush gas tank
    Rebuild carb
    and drive
    When I took the carb apart the casting separated and I am not sure if it will be a problem...what do you think?
    I figure I can throw some gasket maker on it when I re***emble
  2. scrap metal 48
    scrap metal 48
    Is that ^^^a toilet bowl or what???
  3. speters
    speters
    I wish it was it would be cheaper
  4. 31Dodger
    31Dodger
    Zenith updraft carburetor.
  5. F&J
    F&J
    I guess you already know about the Model A parts store and shop in Stafford, right across the road from the Speedway main gate?
    Eric has everything in stock, new/used/rebuilt, and all that small stuff is dirt cheap there.
    "A's and More", Stafford CT
    Edit, Save yourself some breakdowns by buying an intank gas screen. It gets pressed into the gas shutoff valve and sticks upright in the tank. Eric has those, too. I wish I knew about those years ago, they work slick.
  6. 067chevy
    067chevy
    Very nice find!!!
  7. speters
    speters
    Got some work done today. I fixed the motor mount, put a new gasket and filter in the fuel bowl, put in the new ignition key, plopped in the new battery and rebuilt the carb
    gas is a little funky still
    And after completely filling the radiator to the top I discovered the water pump was leaking from the packing on the shaft so it came off
    more progress tomorrow....I want to drive by Friday
  8. ironandsteele
    ironandsteele
  9. Chris
    Chris
    Did you try tightening the packing nut before you removed the pump? They will seep a little...
  10. speters
    speters
    I did try but it would not move and it was quickly turning into a full blown leak and not just a little drip
  11. speters
    speters
    Finished the wiring
    Installed the bulbs
    Installed the battery
    Fixed all the lights
    Repaired front engine mount
    Replaced the belt and water pump
    Flushed the gas tank
    Rebuilt the distributor
    Changed all the fluids
    ...and it still won't run :(
    It sounds sooo close. It will fire but won't stay running and I end up trying for too long and flood it.
    On the plus side I shot a nest out the exhaust like bird shot!
  12. speters
    speters
    It seems like the timing is off a bit anyone have a link to a timing guide for the banger
  13. Fordbarn? Nice start you have there. Will make a great hot rod.
  14. tb33anda3rd
    tb33anda3rd
    remove the bolt in the timing cover with the pin sticking out and turn it around so the pin touches the cam gear. rotate engine, don't use fan you will bend it [and then it will crack and break off] have someone turn the motor with crank slowly until you feel the hole, set rotor to number one on the crank. that will get you started. tweak the timing to the point where the motor sounds late when you retard the spark lever.
  15. F&J
    F&J
    Yea, but does he know how to "adjust" the timing at the distributor, not the lever :)
    Most people don't, he he
  16. speters
    speters
    Just found some good YouTube timing videos so I will give it a try. It seems like the engine only wants to start with the timing advanced
  17. tb33anda3rd
    tb33anda3rd
    then the timing is close. just move it a little clockwise.
  18. speters
    speters
    thanks I will try that first
  19. grm61
    grm61
    from Washington
    A little shot of oil or wd 40 in the cylinders? If things are all dried out you won't have much compression...
    Just a thought
  20. speters
    speters
    Yes I did that and turned the motor a bunch before I tried to start it
  21. 206tee
    206tee
    Great start. You should hop up that banger, put a 4" drop axle with big and little's and call it good. But I'm partial to that set up....
  22. speters
    speters
  23. tb33anda3rd
    tb33anda3rd
    it could be my computer, but timing sounds late. congrats, that's always a good feeling.
  24. speters
    speters
    yes the timing is off that was when it first ran. I have been messing with it all day and I just can't get everything dialed in correctly. I don't have any experience with this engine so I am just playing guess and check.
  25. yetiskustoms
    yetiskustoms
    i want to clean and rub that paint out bad! nice find, poor field car!
  26. tb33anda3rd
    tb33anda3rd
    might have to run it for a while. i have found that motors that have set idle need time to "wake up". valves reseat, oil gets to everything, rings reseal etc.
  27. speters
    speters
    I got it dialed in. Timing was the issue. It much better now. As soon as I get proof of insurance we will register it and start driving outside the neighborhood.
    And of course the starter switch failed about 5 minutes ago so a new one will be needed monday.
  28. tb33anda3rd
    tb33anda3rd
  29. speters
    speters
    I took it apart and cleaned it up, the contact is not the problem. The pedal just goes to the firewall and does not spring back any more
  30. 68Camaro427
    68Camaro427
    Awesome find!! I have it's year-older brother, similarly found in a barn, up by Canada. Mine was different in that the prior owner had rebuilt the engine and the interior had been redone at one time - not show worthy, but usable. I'm about 6'4' and 240, so chop and channel is not likely in my future, either, unless the S10 seat I found will work once I cut it down. With no seat adjuster, I had to take out the seat back and use a blanket so I could fit, shift, and brake.
    I'm just driving mine as is now, though not very far. It beats me up worse than my old Camaro did. Cool to see another one being recycled!! :)
