Cubic Inch question?
Discussion in 'The Hokey Ass Message Board' started by DocWatson, Mar 22, 2008.
  1. I did a search but couldn't find what I was looking for. I would like to work out what a 401 Nailhead cubic inch would be bored 30 thou over? How do I calculate that:confused:
    Doc.
  2. irishpol
    irishpol
    from Texas
    Bore X Pi X stroke X the number of cylinders.
  3. mac762
    mac762
  4. thads31
    thads31
    equation is: 0.25 x Bore x Bore x Pi x stroke x # of cylinders
    (circle area is Pi x radius squared)
  5. irishpol
    irishpol
    from Texas
    Pi R Squared... your right... I must not awnser tecnical questions first thing in the morning:confused:
  6. Big Z
    Big Z
    If you would've bought a hemi instead you wouldn't have this problem. jk
  7. AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHHHH!
    Knew it, should have bought a Hemi!
    Ok, so I need more info on my motor. Wouldn't have a clue about stroke and bore other than its .30 thou over and stock stroke (I don't even know what that is!), the motor is still on its way to me. I think I better invest in a better calculator, this one I got in a show bag just don't cut it!
  8. RichFox
    RichFox
    Bore X bore X .7854 X stroke X number of cylinders. Pie is for eating.
  9. Why cant I find any info on the stock stroke? Anyone know what it is?
  10. Scott
    Scott
  11. Big Z
    Big Z
    I may be wrong, bore 4.1875 stroke 3.640. with .03 over i get 407
  12. Scott
    Scott
    bore=4.1875
    stroke=3.640
  13. panic
    panic
  14. Man, why cant I find that stuff when I look? I feel useless...........
  15. RichFox
    RichFox
    Buy an old Motors Manual on Ebay that covers the years you are interested in. The book has all the diminsions and torque specs. for all American cars made for 7 years before it's publishing date. All kinds of good stuff to look at cheap.
  16. WQ59B
    WQ59B
    Yea: .030 on a Pontiac 400 is 6 cubes, I believe at .030 there is lots of rounding, so even with different bore/stroke sizes, .030 on a 400 V-8 is gonna work out to 6 cubes.
  17. hot rust
    hot rust
    another formula is bore x stroke x 3.1416xno of cylinders
  18. Ruiner
    Ruiner
    3.1416 is Pi, that's the same formula...
  19. Big Z
    Big Z
    The actual formula is ci = (bore/2)sq x 3.1416 x stroke x num of cylinders;
    the area of a circle is A= pi(3.1416) x radius squared; bore is the diameter so u gotta divide by 2
  20. RichFox
    RichFox
    That works good as long as you have a 4 inch bore since the radius of a 4 inch bore is 2 inches and 2 squared is 4. It will not work with any other sizes bore. Say you had a 3.375 bore. Half that is 1.6875 times pi is 3.141. Won't work.
  21. texoutsider
    texoutsider
    from Frisco, Tx
    406.81
    borexborexstrokex.7854x#of cyl...works for me. Have used this formula for many years.
  22. JHhj0978
    JHhj0978
    from Youngstown
    yupp that works!
